#10 |
When you pump the ped the large air bubbles break into many small ones and are hard to remove .Open the valve and press the ped slowly to the floor and shut the valve .wait a few minuts and do it again .After bench bleeding the MC and hooking up all lines sometimes it works to open all valves at once and pump the ped to get fluid going to all the valves .I put a clear hose on each valve going up above the valve so the fluid will cover the valve and the air will travel up the tube and not let the air suck back down into the valve .
