Rep Power: 21 ![]() |
The Rx8 6-Speed into an FB Thread!
Im sure much of the information can cross into other chassis.
General Rx8 Transmission Information Mazda Rx-8 04-current 13B Renesis Gearbox (manual) 1st: 3.815 2nd: 2.260 3rd: 1.536 4th: 1.177 5th: 1.00 6th: 0.787 The most popular "close ratio" conversion i have seen is the miata box. Below is a comparison of the miata box to the Rx8 box given a 9000 shift point and 4.78 final drive (my personal setup). ![]() Now here is the 12a transmission i have currently versus the Rx8. much better! ![]() And also the Turbo II's R type transmission (87-88) compared to the Rx8. Again, 1st and 2nd are similar, but from there on out, for my natural aspiration application, the gearing is superior.
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook Last edited by Whizbang; 11-14-2009 at 05:32 PM. |
Parts Needed For Swap and Other Considerations
-Mazda Rx8 Transmission. 04-08 (not familiar with the newer 09 up models as they are a different manufacture but im assuming this same guide line could work) -Turbo Flywheel and Clutch (compare 235/240 to the 236 of the Rx8) -Rx8 Starter -Rx8 Shifter -Metal stock for the transmission mount -Solution for the slave cylinder, will finalize something soon enough -Final solution for drive shaft will come soon. Output shaft is same as a turbo II though. Things to Think About Now my setup lends this swap to be simpler than most. The transmissions in the FB were shorter than the FC chassis so the shifter position is not as effected as the FC will be. For the FC the shifter will move 3.5" forward. This will be less for the FB. Guesstimating around 2" to 2.5" for the FB. Add that to the fact im tall and the shifter location is essentially a non issue. Also, i dont have a speedometer so the whole electronic speedo thing is a non issue for me. If you happen to want to retain the mechanical speedo, then well, you have problems that im not going to address for you. Real men don't need speedos. Or wear them. Its a man law.
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook Last edited by Whizbang; 11-14-2009 at 07:11 PM. |
Transplanting the Rx8 Transmission
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook Last edited by Whizbang; 11-14-2009 at 07:00 PM. |
Comparing the Rx8 Transmission
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook Last edited by Whizbang; 11-14-2009 at 07:01 PM. |
Results
Rep Power: 10 ![]() |
Lemme know if you need any measurements, diameter, splines, etc etc etc.... I have that box dissasembled on my work bench right now.
i wouldnt mind an any and all if you can. Also note my pm.
in particular, the input and out splines and diameters, length of the transmission, pictures of mount location etc.
#9 |
Subscribed! I am very interested in your results.
2004 RX-8. I would love to tune it but can't find the right parts for Microtech
#10 |
minor update, i have sourced myself two transmissions, maybe three. Moving at the end of this month so i wont be messing around with that for a little while still. But once i have them on hand ill be taking them apart.
#11 |
Rawr Bearclaw
I'll be doing this soon in my FB with a NA 20B powering it. Gonna move the whole engine back to get the shifter to line up and help with the weight balance a bit.
Illicit Performance Rotary building, porting, tuning, chassis dyno services www.illicitperformance.com |
#12 |
aka boostaholic13b
I am considering this behind a 13bt in my 83 but i see the results are for a n/a app.
#13 |
Murderilcious
Any updates?
#14 |
I have Ultra power in me.
Rep Power: 15 ![]() |
I thought the RX-8 trans was not that strong. weaker then the TII
#15 |
Rep Power: 20 ![]() |
