Old 03-24-2008, 02:59 PM   #1
Ender
rotors excite me
Ender's Avatar
Originally Posted by classicauto View Post
1: You could go out a little further by the looks of it, but you'd need to mock a rotor/shaft up and spin it just to make sure the side seal and corner seals are supported because yes, thats where they ride.
Will do.
2: I don't understand this question. Are you talking about closing the port later, or changing the angle of the bowl at the closing edge?
I mean cutting down (if the iron is laid flat on a bench). However cutting down more will necessitate changing the angle of the bowl at the closing edge. I want to know what ought to be ideal. I will state my intentions with the motor soon, as I now realize that's important to this discussion.
3: Thats up to you and your plans for the engine. I'd go until the port is flush with the template 2D wise.
I have been doing that. There's a thin scribe mark on the template, and you can still see it on the template. I'm asking if I should cut off the tiny bit of metal that makes up that scribe mark all around the port outline on the template.
4: Again depends on your purpose for the engine. If the template laspes into the oil control ring area, I personally wouldn't go there on a street engine, but some say you can without many negatives (which is cutting into the first edge slightly) but I wouldn't.
looks pretty good though. Bowl and backcutting also seem decent!
Yeah, I'd prefer to leave the control ring area alone. This is intended to be a mild streetport with the potential to make 300+hp to the wheels later on. I'm going to run the stock turbo for a while, probably more than a year after the motor is installed, but once I have the means I will want to upgrade my turbo (and probably go standalone) and head for the mid 300's. I want it to be efficient, as economical as possible with regard to fuel for commuting, and make good power. I have all new seals/gaskets and good quality used housings, irons, and I think my rotors and e-shaft are in good shape. I'd like to have the rotors trimmed/bevelled/port phasing (there are a number of names for it I guess), but I doubt I'll get to that point. I will be running the stock ECU except for having the Rtek 1.7 chip (so I also have 720cc secondaries), I already have an SAFC-II set up running the throttle off the boost signal. I'm working on scrounging up the money for a zeitronix wideband, but idk when that will happen...
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
