REVIT
Pictures of horn location
I'm trying to install my horns but cannot remember where they are mounted. I know they are mounted behind the front bumper cover but which holes to use?. Does anyone have a picture of the location?
Thanks |
Are you running a stock front bumper with the reinforcement? I believe that it is the holes on the outer most section of the front cross support bar. The ones outside of the ground strap connections.
Here is a shot of mine. The passenger side is in the correct spot I think,..I run a GTC front bumper so i have moved things around alot cleaning up the bay area
REVIT
Horn Location
Thanks for the response. I do have the stock bumper cover.
The Professional
hahaha...not to thread jack but anyone know where the airbag sensors are? thanks...
There is one that is located on the hood latch itself. It feeds along the cluster of wires back to the ABS unit area. The LFT and RGT side sensors I believe mount next to the oil coolers on the frame rail. I will double check on my car. That is where the FSM is pointing me though.
After looking at mine they are in fact mounted near the oil coolers. They mount on the inner support above the oil coolers. I snap a pic tommmorow if you need one. Dave Last edited by BigIslandSevens; 11-04-2009 at 09:19 PM. |
REVIT
Airbag sensors
Yeah the front ones are mounted next to the oil coolers. The hood latch and there also is one under the dashboard in the center of the car up against the firewall.
Bubble Tech
sorry pics are small but take a look this might help
http://s426.photobucket.com/albums/p...103082103a.jpg scroll through these and will give u general idea where they go http://muibubbles.blogspot.com/2008/...mentation.html |
REVIT
Horn
hey thanks for the reply. The pictures helped alot.
#9 |
Bubble Tech
np, i learned things tend to be a lot easier with pics! im a visual learner so i try and take a lot of pics!
#10 |
2001 RX-7 RZ
Change them and put RX-8 horns on it.
Your FD will love you for it. They are MUCH better.
#11 |
REVIT
Horns
Where did you get the RX8 horns. They do look cool. Is the sound any different?
#12 | |
2001 RX-7 RZ
They sound much better than the poxy originals.....and have a good quality baaaarp sound. Find an RX-8 and try them out.
#13 |
REVIT
Horns
Thanks
#14 |
Half bubble off plumb
the Rx-8s do sound better.... but if you really want a kick in the ass everytime you hit the horn, check into these...
Hella Supertones http://www.rallyarmor.com/store/hell...nes-p-159.html big with the STI, EVO crowds... they reach 118Db, they are awesome loud.. I have them on my Daily Driver Integra... such a surprise to other drivers.. lol!!! J. |
