Old 09-04-2009, 12:51 PM   #1
4000 ish RPM break up..
So, this is kind of weird..
My car breaks up around 4000 RPM when the engine is not fully warmed up.. Anyone know why?? My only guess at this point is the coolant bypass to the TB and TB isn't warming up quickily.. Has anyone else noticed this issue?? and any solutions?
Thanks!
PHIL
Old 09-04-2009, 09:36 PM   #2
9G Redline
9G Redline is on a distinguished road
Phil, you wouldn't be talking about the rev limiter for the engine when the engine is cold would you?
Original owner of a 04 WB Rx8 6spd Touring. Mazdaspeed CAI, MS Dual Catback, Voodoo knob, Boston Audio, AP Pulley, Rotora slotted rotors w/ Hawk HPS pads. 2nd engine @ 83,147 miles.
Second owner 2005 Mazda 3 5-speed (Traded)
1st owner 2010 Black Mazda Mx-5 6-speed with PRHT.
More mods and rotaries to come!
9G Redline is offline   Reply With Quote
Old 09-05-2009, 11:31 AM   #3
chickenwafer
Boost Whore
chickenwafer's Avatar
chickenwafer is on a distinguished road
If you have the latest Mazda flash they lowered the threshold for revving a cold engine. If it only does it when it's cold then it's probably that.
chickenwafer is offline   Reply With Quote
Old 09-05-2009, 11:00 PM   #4
Really?? I didn't know they did that.. But it does rev up to 6+K under low load..
Old 09-06-2009, 12:44 AM   #5
Dzire
Dzire's Avatar
Dzire is on a distinguished road
my car done this since the day I bought it only in the winter time I think when the car is below 100 in it runs really rich causing ignition breakup when it warms up it runs fine
RX8 2004 GT
RX7 1988 TII
Dzire is offline   Reply With Quote
Old 09-26-2009, 12:52 PM   #6
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
^Spot on, also the flash program will not allow it. Helps save the engine...
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
Old 11-26-2009, 11:54 PM   #7
Renesisking
Renesisking is on a distinguished road
yea i lose power from around 3k-4300k then i lose it from 5ish to after 6500rpm, then i just have no pull up to redline, this is my second engine, i took it to a different dealership and they said that my intake manifold wasnt cleaned properly is all gunked up....any ideas??
I put in new sparkplugs very recently, i barely have a thousand miles on them.
2004 RX-8. I would love to tune it but can't find the right parts for Microtech
Renesisking is offline   Reply With Quote
Old 12-01-2009, 06:28 AM   #8
Nutsid
Temporarily insane.
Nutsid's Avatar
If your intake manifold is all gunked up... that is your answer.
Kindle
Nook
Old 12-05-2009, 05:43 AM   #9
DOMINION
KOOL AID KILLER!
DOMINION's Avatar
DOMINION is on a distinguished road
I dont have this issue at all. In fact if I dont let my car warm up to operating temp and drive my rpms try to pull up fast at 5, rpms
DOMINION is offline   Reply With Quote
Old 02-09-2010, 10:31 PM   #10
scottie0330
scottie0330 is on a distinguished road
any ideas on how to clean the intake manifold valve?i just got a 04 rx8 and the light came on and said that the intake manifold valve was stuck open.iv been trying to find out what it was and how it effects the car.
scottie0330 is offline   Reply With Quote
Old 02-09-2010, 10:46 PM   #11
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
Check the SSV valve its also got a tsb. Here is a video of them cleaning it http://www.vimeo.com/7093611 I cleaned mine and it helped. It needed to be cleaned and it didnt throw a 2070 code. so it could be that even if it has not pulled a code yet.
mazdadude7 is offline   Reply With Quote
Old 03-09-2010, 08:50 PM   #12
scottie0330
wow man thanks for the video!thats going to help alot.how was your car running with it dirty?did your mpg go down?and this looks like something i might can do over a weekend but what was used to clean it? this is my first rotary car so i dont really know that much about whats going on with these valves and stuff.thanks for the help.
