Old 09-15-2009, 01:50 PM   #1
88moneypit
88moneypit's Avatar
88moneypit is on a distinguished road
stock wheels
so does anyone know of some really (light weight) stock wheels that ford, chrysler, or mazda made that would look good on a 2nd gen?
88moneypit is offline   Reply With Quote
Old 09-15-2009, 02:23 PM   #2
need RX7
Clean S4 Nutswinger
need RX7's Avatar
The BBSs from convertible FCs are very light and look good.
Old 09-15-2009, 03:12 PM   #3
Since the 5 x 114.3mm bolt pattern is known as a "luxury" bolt pattern, I doubt you'd find something "lightweight" from any of the domestic cars.
Most of the 5-lug domestic wheels are either wrong bolt pattern or from super heavy cars that don't give a rip about weight.
GM Camaro and Corvette patterns are 5 x 4.75", so it doesn't fit our 5 x 4.5" pattern.
Pontiac makes a stupid 5 x 115mm (who the f*ck makes a one-off pattern like that???).
Most of the (newer) Ford Mustang wheels are the right bolt pattern, but I would never consider them "light".
It's your best bet to find some Mazda ones.
Like need_RX7 already mentioned, the vert 15" wheels are light, but you're stuck with the 15" x 6.0" size.
If you can find some Kouki Turbo II / GTUs wheels, those are 16" x 7.0", and weight significantly lighter than the Zenki Turbo II wheels in the same specs.
Old 09-15-2009, 07:21 PM   #4
Stock wheels from a 3rd gen slushbox equipped car.
Old 09-15-2009, 11:53 PM   #5
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
bbs off a lexus i believe it is, same design as vert rims, half inch wider
Old 09-17-2009, 07:57 PM   #6
88turboii
destroy, rebuild, repeat
88turboii's Avatar
these are from a pontiac grand prix 16x8, 25mm offset. they weighed exactly the same as the stock s4 TII wheel with tire, but 1 in wider
there is also a crown vic/grand marquis mesh type wheel 16x7 that has a decent offset, not sure about weight
Old 09-17-2009, 08:26 PM   #7
josh18_2k
17x8 mstang gt wheels are 19lbs
Old 09-20-2009, 04:29 AM   #8
sen2two
KTEC
sen2two's Avatar
FD wheels are almost the best choice. rx8's look nice too. but those grand prix wheels lookgood too! also the grand marquis mesh wheels look similar with a bigger lip and perfect fit. plus many more people dont know about. i seen a FC with 18" wheels from a dodge magnum that looked pretty nice.
what I have:
What I had:
Old 09-20-2009, 06:02 AM   #9
Both of these have identical width and offsets.
They both require big spacers to fit up front.
They will fit in the back but have that "sunken" look which a lot of people don't like.
Old 09-20-2009, 12:02 PM   #10
My5ABaby
My5ABaby's Avatar
Have any pics of how they fit with the fenders? Any spacers needed?
Community Service Manual
RotorWiki
Old 09-20-2009, 10:08 PM   #11
That is all
Old 09-21-2009, 03:18 AM   #12
sen2two
KTEC
sen2two's Avatar
for FD and rx8 wheels you need a 25mm adapter in the rear. and a 20mm adapter in the front. this will give a perfect fit.
what I have:
What I had:
Old 09-24-2009, 08:58 PM   #13
88turboii
88turboii's Avatar
no spacers needed
these are with 205's, im now running 225's and it rubs a little under the wheel well but its low as hell i just need to bump the ride height up a little
they also came in gold
http://www.finishlinewheels.com/PONT...92/A-01660U15/
Old 09-24-2009, 09:17 PM   #14
dude, how did those fit? Pontiac, and most gm are 115 not 114.3 pattern, so those should just BARELY be wrong fitment....
check your lug bolts, and studs for anything bent, warped, or thread damage. I will be surprised if you dont find some.
uness they have epitrochoid lug holes like some wheels i found at the junkyard.
note, the above were really wide 15" wheels with what looked like cast aluminum centers and the rotor housing looking bolt holes were cast in, NOT drilled or anything.
Old 09-25-2009, 02:54 PM   #15
88turboii
88turboii's Avatar
i havent had any problems with them. if the bolt pattern is 0.7mm off, then each hole is only ~0.35mm off, which apparently isnt enough to be a problem
