Old 09-09-2009, 07:57 PM   #16
Buy any of "cheap" ATF.
Don't buy the stuff that's specific to one model - i.e. Honda.
Old 09-09-2009, 09:15 PM   #17
NoDOHC
NoDOHC's Avatar
A few additional pieces of info:
The engine idles rather smoothly for a dead face on a rotor, but revs very slowly (like it is running on one rotor).
We unplugged each rotor in its turn. The engine sputtered and died if the front rotor was unplugged, but did try to stay running. The engine sputtered and died almost as fast when the rear rotor was unplugged (still trying to stay running).
The engine would not start on either rotor alone.
This goes against my previous experience with blown rotaries, when they would start and run and drive fine (except for extreme gutlessness and very hot exhaust).
I guess I am not sure that this is an engine issue or if it is a fuel injection issue.
It almost acts like it is running very rich or has very retarded timing.
Maybe we can pull the exhaust manifold off and look at the apex seals, that will indicate if the engine is worth rebuilding.
Old 09-10-2009, 05:31 AM   #18
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
youll have to let me know when youre free next. well have to get something going.
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 09-10-2009, 11:38 AM   #19
You need to try and do some basic troubleshooting then?
Eliminate ignition (spark) first, since this is the easiest.
First, confirm all 4 spark plugs are firing.
Then, confirm (with a timing gun) that they are firing at the proper moment.
If ignition system looks good, move onto the fuel...
I would swap the fuel injectors just as a test - does the problem change?
Swap either front to back (primaries) or swap primaries for secondaries.
Also, might want to check spray pattern from the primaries by tying the fuel injectors to the rail and crank the engine with the injectors out of their holes - helps to have a friend here.
Old 09-13-2009, 08:27 PM   #20
Before fiddling with swapping injectors I would make sure that there is proper rail pressure. It could literally be as simple as a bad pump, regulator or even a clogged filter.
Old 09-13-2009, 10:40 PM   #21
NoDOHC
NoDOHC's Avatar
For that matter, I have lots of good S4 injectors, I will bring a set down (but I am guessing that is not the problem, I think it is sensor related). We will check the timing too. (I know all coils are firing, we already tested that). If the engine didn't idle so smoothly, I would be guessing vacuum leak.
Fuel pressure is also a good one (I think I have a gauge somewhere).
It is also possible that I have driven my Haltech '86 so long that I forgot how slowly stock rotaries rev. (although I think the '91 revs faster).
Old 09-14-2009, 05:38 AM   #22
Silver86
now what?
Silver86's Avatar
what i think ill do before we get busy with this... im gonna buy a new fuel filter and some newer gas... the 1/4 tank thats in there now is the same 1/4 tank that was in there when i bought the car.
aka - 20bforme
atf, mmo, seal, side, stuck
