Old 06-12-2009, 08:50 AM   #1
otterbob
member
otterbob is on a distinguished road
1st Gen/RX8 motor/trans install
Has anyone tried installing an RX8 motor or motor/trans in a 1st Gen yet? If so, what are the issues with this swap? I know there will be some front mount difficulty but I'm just starting to explore the feasibility of this conversion.
otterbob is offline   Reply With Quote
Old 06-12-2009, 10:34 AM   #2
Kwerks
FD Spirit
Kwerks's Avatar
Kwerks is on a distinguished road
That would be a perfect match.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Kwerks is offline   Reply With Quote
Old 06-12-2009, 10:42 AM   #3
Been done about 3 years ago. Makers-7 I believe.
They even installed the dashboard, but this is the only pic I could find.
Old 06-12-2009, 01:49 PM   #4
JShiz
ZOMG WTF BBQ!!!
JShiz's Avatar
I'd imagine the electrical part would be a major head ache but 200+ hp in a FB would be perfect
Old 06-12-2009, 02:56 PM   #5
They used the main harness for the Dash/ECU/Engine all from the RX-8.
Luckily, the chassis harness and the engine harnesses are separated well in RX-7's. If you look at the dash, you can see the plethora of warning lights because of this (steering fault, ABS, traction, air bag, etc.
So that would be annoying.
Old 06-12-2009, 10:15 PM   #6
^ True, but that may also be because the key is in the "ON" position... all of those light up when you do that...
I always thought it woudl be a great modification. It would be nice to see an aftermarket simplified manifold for the MSP that would allow you to run either a weber down draft or ITB....
Old 06-12-2009, 10:58 PM   #7
Rogue_Wulff
Non Member
Buddy of mine is putting a Renesis into his FB racecar.
Gonna use a home made header, and intake, along with a side draft carb.
He's using his 79 to test fit everything, then it will be swapped into the track car in place of the current 4p 13B SP.
Old 06-13-2009, 01:18 AM   #8
I think this swap will have the same hurdles as any other 8 swap:
-custom mounts for engine and/or tranny
-a new dash or the 8 dash so it all plugs in and works (no need for a standalone) don't know if you can use a HUD system with the stock 8 stuff, never seen it done....
-look into the length of the tranny too, in case you need to cut into the tranny well....then the DS in case it needs to be custom to fit
Never seen anyone do a write-up on this so if you end up doing more research please post your findings.
Old 06-13-2009, 02:16 PM   #9
j_tso
j_tso is on a distinguished road
Racing Beat makes a $500 header for Renesis, but I'm keenly interested in seeing how a carbed Renesis would perform. Probably not as well as the injected, six port system, but hopefully better than a S4 6port 13B.
j_tso is offline   Reply With Quote
Old 06-13-2009, 02:43 PM   #10
Rogue_Wulff
Non Member
Yeah. Unfortunately, he bought a 2004 model from an AT car. 4p intake.......
Upside, it came with a counterweight, simplifing the installation of the light steel flywheel.
The RB header would be great, but it prolly wouldn't hook up to his RB RR center section.....
Although I did finally convince him to ditch the flowmaster muffler. Those sound like pure crap on a rotary.
Old 06-18-2009, 05:01 PM   #11
otterbob
member
I guess what I'm thinking is this - I've seen wrecked rx8's for around 6k,low mileage, undamaged drivetrain. Mazdatrix sells a ported 13b w/12a ends (drop in 1st gen) for about the same money. More work to part out the rx8 but you get a 6 speed too. How much HP is intrinsic to the rx8 motor and how much comes from the engine mgmt. sys.? Would a sidedraft setup diminish output that much?
Old 06-21-2009, 01:49 PM   #12
diabolical1
I have radioactive semen
i have often thought about doing a swap like this, but the sad truth is i'll probably never get around to it. however, i believe if you plan it out right, you could probably do the swap and retain much of the power (more importantly, the powerband), which would make for a pretty hot car.
Old 06-21-2009, 02:10 PM   #13
well, if you bring it up then you should buy the mazdatrix engine...much simpler and a lo less work then the full 8 swap.
