		#61 |
				Rep Power: 19 ![]()  |
			Engine harness eh? I have not seen yours... hell, I haven't seen mine in about two years
		#62 |
				Rep Power: 20 ![]()  |
			I'll give you a hint:  I'd be tempted to thieve his harness for what's on it and how it's made.
	The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group  |
		#63 |
				Rep Power: 10 ![]()  |
			I'll snap a few pics of my harness....  Maybe link a few from TeamFCS3
			So, another slow night with not much accomplished. Still powdercoating and prepping a bunch of stuff. The last part is coming in tomorrow..... the nylon seal around the o-ring in the front cover ![]() Anywho - since I'm a pic whore.... here's some more New EGT probe and the stainless line is for the ole' e-map Turbos on and all the oil/coolant lines run. Yes I powdercoated the coolant lines. I'm trying not to miss any detail this time around And the twins pretty much done. Waterpump assembly just sorta hanging out. Not going to snub that up until I get the front cover completely dealt with. Which will hopefully be tomorrow  |
		#64 |
			so many wires and lines!
			For the front cover do you wait until you've mounted it before putting on the front ring (I think it's an oil control ring or something--the orange one)?
		#65 |
			Being that this is going into an FC, any reason why you decided to keep the RE water pump housing and cap configuration?
	I'm drooling over your progress though... looks very very clean! Your not planning to use a CAS system either?  |
		#66 |
			 crash auto?fix auto
				Rep Power: 18 ![]()  |
			If he's waiting for the nylon seal, its likely the o-ring that will cause 0 oil pressure if it falls out or breaks.  The one coming off the oil pump feed in the front iron.  should be mounted when the front cover is (finally) mounted along with the front cover gasket etc.
		#67 | ||
			LIES!  That's the simplified version of everything.  You should see what a stock 13B-REW or RE looks like!
		#68 | |
    You'll see why I went this route when I get some pics of the HMIC system up.  It works oh so well and looks OH so sexyThanks... Now I just need to get it in the car..... actually I need to get some stuff on the car. It hasn't changed in a week. Kinda depressing. No, I am. I just tapped the opening off for paint. I actually stabbed the CAS tonight as well as Finished the end float Installed the Front Cover Finished the turbos Finished the fuel Got the UIM mounted Modified and Installed the Oil Pan. Left is to powdercoat all the springs on the TB and assemble it, put the motor mounts on, finish the mounting for the coils, but I can't do that until the motor is swinging........ oh, dissasemble and powdercoat an Alt.... Yeah, trying not to miss any detail. Hopefully it doesn't keep me from actually attending DGRR.... um - new used wheels will be here tomorrow. Need to refinish them which will take about a week probably..... Anyone wanna come help out this weekend? Free beer. So yeah, I cut off the drain plug and welded on a -10AN bung. No more changine gaskets and no more drain plug leaks for me! And with the Banzai Brace there shouldn't be any leaks, and if there are, they'll be easy to spot because I powdercoated the pan Plantnium SIlver. I would've liked to have painted it, but I used the last of the paint last night on the Pre-spool, wastegate, and turbo control actuator.  |
		#69 |
			Note to anyone using the 13B-RE oil pan with different housings, the baffle for the regulator needs to be trimmed.  I learned this AFTER I layed down a bead of RTV.  I was beating the shit out of it cursing the Banzai studs until I looked at it and realized what the problem was.....  Oh well, it's curing now.
		#70 |
				Rep Power: 0 ![]()  |
			i am completely envious of the extent of your build. but my car is in the very beginning of the build. just finally got the bay completly stripped and working of cleaning cleaning and more cleaning.
	![]() 1986 gxl on stands for restoration and swap ![]() 1987 base model needs paint and body but works for a dd 1988 base parts car with t2 swap. 1988 jeep comanche off road machine.  |
		#71 |
			BTW, to update my earlier comment:
			What I like in the build the most, is that this car follows both Function AND form! To me, this aspect is very important, because a lot of people tend to focus on one and ignore the other.
	Rotaries:They are NOT that complicated!  |
		#72 |
			Its been a long weekend, where's an update, lol....
	Agree w/ Max BTW...  |
		#73 |
			 ORD - Old Rotary Dude
			This is crazy man! I thought I was the only one that had this wild idea that my FC would be ready by DGRR 09. What was supposed to be a 7 year project for myself and my 9yo son was jump started 3 weeks ago when I trailered a dead TII back to the shop. Now the project has turned into a 6 week deal. As of this past week we were still pulling things off. This week and until 4/15 we will be busy installing the new stuff and fabbing up the new parts.
	Not trying to jack your thread...just wanted to say that you are not alone brother and great work so far. If you need some help on that aluminum welding let me know...I tig everyday. Let's get these cars ready and hookup at the Gap! Todd B.  |
		#74 | ||||
 He sighed and rolled his eyes as I pointed out a few bolts that I powdercoated last night ![]() Quote:
		#75 |
			 Clean S4 Nutswinger
			Sexy build, man.
