Old 01-29-2009, 01:27 AM   #1
tribeofjudah
tribeofjudah's Avatar
tribeofjudah is on a distinguished road
Windshield Wiper Malfunction
Hello experts,
My vert has had this problem for a while. The wiper switch is down to ONE speed only - low....no fast, no intermittent. It's all together with the hazard and the vert open/close control. I thought it was the switch so I bought another one (used) and plugged it in. Same thing - one speed ONLY.
Either the replacement is bad too OR it's something else altogether. Maybe it's the motor itself. Maybe I should have bought a NEW SWITCH at $250.... kinda steep if you ask me...
Any advice out there.........???
tribeofjudah is offline   Reply With Quote
Old 01-29-2009, 05:06 PM   #2
Hey Pheonix lookie what I found:
http://fc3spro.com/TECH/HOWTO/WIPER/wiper.html
Not only is it a how-to it's also gives the location to pick up the relays. Enjoy.
Old 01-29-2009, 07:33 PM   #3
yea the issues with the wiper switches are a common issue.
Old 02-01-2009, 12:41 AM   #4
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
To add my .02 ... this is about a medium difficulty fix if you have any sort of soldering skills. The hardest part is desoldering the old relay without burning anything (I tried both solder wick and two solder suckers and found the wick MUCH easier). It's very likely that both switches you tested are bad as this is a very common issue.
1988 GXL
Old 03-17-2009, 11:44 AM   #5
yeahbuddy
yeahbuddy is on a distinguished road
Wiper Switch Problems
I have a similar problem. My original switch on my '91 only works on low and I just replaced my switch with a working switch I bought on ebay. Now the wipers run all the time no matter what position the switch is in. Any ideas?
yeahbuddy is offline   Reply With Quote
Old 03-17-2009, 12:00 PM   #6
Probably the wrong series switch in the wrong harness. IE: S4 in an S5, or S5 in an S4.
Old 03-17-2009, 12:04 PM   #7
yeahbuddy
Well that sucks but makes sense. My car is an S5. Time to take the dash apart again
Thanks
Old 03-18-2009, 06:10 PM   #8
drift7
drift7 is on a distinguished road
I had this problem as well, but my wipers don't work at all now.. Can anyone help?
drift7 is offline   Reply With Quote
Old 03-18-2009, 08:26 PM   #9
switch is probably burned out, but we really can't tell you anything unless you test the circuit. Break out that multimeter and find out what the voltages are and compare those to the FSM.
Old 01-22-2010, 01:27 PM   #10
Pele
Pele is on a distinguished road
I've never had this problem... I've tested several S4 and S5 switches in my S4 GXL... Both Vert and Coupe models too.
Pele is offline   Reply With Quote
