Old 03-01-2009, 12:41 PM   #1
Garfinkle's Custom 99 Rotor Cross drill (ton of pics)!
Well, I was searching for some cross drilled rotors to replace my 99 spec rotors.. But after searching and realized how expensive it could be (800-900 for JUST fronts), I've decided to take my near new 99 Stock rotors to Garfinkle.
I'll be honest, I was mainly looking for look vs. function (but 99 brakes are noticeably better in general vs stock 93+).
Anyhow, I am super happy with the results. Garfinkle worked out the harmonics of cross drilling and counter sunk ever hole! This particular custom drilling took him many hours of planning and many hours to drill (as you could see by number of holes).
Also drilling probably lessen the weight of the rotors by couple of pounds (i didn't think to weigh it, but did feel lighter).
If you have 99 rotors or any other rotors you want to custom drill, definitely sent them to Garfinkle! He knows what he's doing.
This particular job will cost you $250 + shipping. Personally, I think its worth the work! I'm going to put them on today and will post some pics on the car.. Mean while, please look at the rotors off the car.
Old 03-01-2009, 08:12 PM   #2
Brent
Sua Sponte
Brent's Avatar
Work looks amazing as always. Are these going on your MB FD Phil?
Old 03-01-2009, 09:08 PM   #3
Yeah, these are going on the MB.. I was also rebuilding the 99s this afternoon but had to stop to come in to work
Old 03-01-2009, 09:28 PM   #4
hades
nice.
What the difference between 93-95 and 96+?
This is going to tear
Old 03-01-2009, 11:32 PM   #5
Someone should correct me if I'm wrong about this..
But I believe ONLY RX7s that came with 17 inch wheels got the larger rotors... 99+ RZs and such.
Once you go 99+ larger brakes, you can not use your 16 inch wheels.
Old 03-02-2009, 02:02 AM   #6
Trout2
Trout2 is on a distinguished road
Correct, the larger brakes came on models with 17 in. wheels for 1999-2002. Won't fit with the stock 16's, I tried just to see.
The later brakes use 12.3 vs. 11.6 in. rotors. Front calipers have revised piston sizes. Rear calipers are no different except for mounting tabs to place them out further.
Jack
Trout2 is offline   Reply With Quote
Old 03-02-2009, 05:32 AM   #7
Garfinkles Motor Works
The stock rotors can be drilled also .The smaller rotors have a different number of vents and can be drilled in sweeping paterns,as mine are .
Old 03-02-2009, 07:08 AM   #8
hades
how much larger are they?
Old 03-02-2009, 07:21 AM   #9
Jack posted couple of posts up
But I'll put some comparison pics for you.
Racing brake BBK rotor, 99 Rotors, and 93 rotor
99 vs 93..
99 vs 93.. 99s are much thicker
99 vs 93..
Racing Brake vs 99..
Old 03-02-2009, 12:45 PM   #10
zonblitz
zonblitz's Avatar
zonblitz is on a distinguished road
Looks great! Props on a great job!
zonblitz is offline   Reply With Quote
Old 03-02-2009, 10:43 PM   #11
Pics of the rotors on the car..
Old 03-03-2009, 05:39 AM   #12
That looks so good ,you should double my pay .HAHAHA
Old 03-17-2009, 11:00 PM   #13
LOL! thanks again David!! Now I need you to make me that pulley thingy we talked about.. if you don't mind
Old 04-17-2009, 06:27 AM   #14
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
99 Spec rotors
What parts are required to change to use the 99+ rotors?
REVIT93RX7 is offline   Reply With Quote
Old 04-17-2009, 07:42 AM   #15
Brent
Sua Sponte
Brent's Avatar
You need the 99+ calipers to use the rotors. If you haven't already, I would advise replacing your brake lines as well. The backing plates are larger as well. I know some people have cut the old ones off. The part numbers for all of these components can be found in the stickies at the top of this sub forum.
