Old 02-20-2009, 08:02 PM   #1
gotina79
gotina79 is on a distinguished road
new 2 rotary
hey im lookn for info on building a 13b bridgeport carb motor for my ford cortina prty new 2 the hole rotary motor so ne help much apreciated
gotina79 is offline   Reply With Quote
Old 02-20-2009, 08:45 PM   #2
well there are a few things you need to decided. Mostly on which generation 13b. I would recommend use of S4 or S5 13B due to them being the most common, lowest weight and an overall lower cost. For the ease of a swap, if so inclined, you can use a 12a front cover and have the front cross brace if it makes the swap easier.
Old 02-21-2009, 12:18 AM   #3
gotina79
cheers . looking at s5 block with s4 rotors could you tell me a bit about different porting, bridge, tall port, pp etc
Old 02-22-2009, 02:38 AM   #4
Rotarydave
Rotary Nut Case
Rotarydave is on a distinguished road
Welcome, Porting also is determined by the type of induction you want to use as well, some types of induction don't like port overlap so massive porting is not always the best way to go.
Rotarydave is offline   Reply With Quote
Old 02-22-2009, 03:52 AM   #5
gotina79
hav 48mm ipa carb.
