Old 01-19-2009, 11:20 PM   #1
lcrotaryracer
lcrotaryracer is on a distinguished road
clutch info
can you use a turbo clutch on a nt will it line up?\
thanks tim
you can always have fun in a rx7
lcrotaryracer is offline   Reply With Quote
Old 01-20-2009, 12:54 AM   #2
No. The disk itself is a different diameter. I never tried matching the pressure plate once I realized it was the wrong clutch so, I don't know if you can use the PP with an NA disk.
Old 01-20-2009, 04:13 PM   #3
It will line up, but the disc and PP are larger. There are clearance issues.
So, in easy terms....NO!
Old 01-21-2009, 02:41 PM   #4
Jeff20B
Jeff20B's Avatar
Splines are different.
Old 01-21-2009, 03:19 PM   #5
^That too^
Old 07-17-2009, 09:08 PM   #6
pachizeron
pachizeron is on a distinguished road
Hey buddy, you can't use a turbo cluth. It won't line up since the disk has a different size. Good luck!
mazda parts
pachizeron is offline   Reply With Quote
