Old 12-18-2008, 10:15 PM   #31
farberio
farberio is on a distinguished road
Originally Posted by classicauto View Post
The plates won't matter - the housings are where the main difference (width wise) is at.
If there's 13B rotors/housings - 13B width
If there's 12A rotors/housings - 12A width
Right...but...you tell me how you can mix and match 12A plates and 13B Housings/Rotors.
farberio is offline   Reply With Quote
Old 12-19-2008, 08:28 AM   #32
88moneypit
88moneypit's Avatar
88moneypit is on a distinguished road
and the final verdict is?
88moneypit is offline   Reply With Quote
Old 12-19-2008, 08:51 AM   #33
drewski86
Slow
drewski86 is on a distinguished road
Internal have to match the housings you're using (e-shaft, rotors, etc.) but the irons are innerchangable. The housings and irons need to be pre '86 so the coolant seals match.
drewski86 is offline   Reply With Quote
Old 12-19-2008, 11:07 AM   #34
^So the plates can be swapped...I thought I had heard you could, but wasn't sure.
Old 12-19-2008, 11:11 AM   #35
88moneypit
88moneypit's Avatar
i would hope its possible...its already built...lol....im definetly doing the turbo setup though....gonna use a stock turbo ii setup with the webber....just to see what it pushes...hoping for the best
Old 12-19-2008, 11:38 AM   #36
A blow through system can yield good results. But then again, it is ALL in the tuning!
Old 12-19-2008, 11:50 AM   #37
Yes...Pick up a wideband before you start screwing with anything...And make sure your carbs are properly prepped for boost. Rotaryshack would probably be a good place to look for blowthrough carb info
Old 12-19-2008, 11:52 AM   #38
88moneypit
88moneypit's Avatar
so whats a blow through setup?
Old 12-19-2008, 12:02 PM   #39
Where you have the turbo compressor outlet running boosted air into the carb....Hence the the turbo pressure is "blowing through" the carb as opossed to some older setups where the turbo inlet sucked air through the carb (Draw-through setup)
Old 12-19-2008, 12:03 PM   #40
88moneypit
88moneypit's Avatar
oh ok gotcha......they go for a pretty penny?
Old 12-19-2008, 12:06 PM   #41
IDK, never really looked into much... But check out www.rotaryshack.com IIRC, they had a 700+whp blowthrough 12a setup
Old 12-19-2008, 12:07 PM   #42
88moneypit
88moneypit's Avatar
holy hell...lol.....thanks man
Old 12-19-2008, 12:09 PM   #43
Do know for basics you need an exhaust manifold and downpipe, carb hat, make sure your carb is properly prepped, if you are running over about 8 psi you should get an intercooler or water/meth injection setup, rising rate fuel pressure regulator, 255lph fuel pump.
Old 12-19-2008, 12:12 PM   #44
88moneypit
88moneypit's Avatar
now the hard part is who can help me tune it all around here?
Old 12-19-2008, 12:21 PM   #45
Idk, Vinnie is one of the only people I know with any real carb experience on rotaries around here, but he is N/A
