Old 12-16-2008, 06:09 PM   #16
You're not giving us enough information, so we can't give you a detailed answer...
"Diesel turbo" and "7psi" doesn't tell us jack shit.
At minimum, we need to know:
compressor wheel trim - inducer (minor) and exducer (major) wheel diameters
turbine wheel trim - inducer (major) and exducer (minor) wheel diameters
turbine A / R
Until you can give us these specs, others are only going to give you a WAG...
Old 12-17-2008, 12:09 AM   #17
farberio
farberio is on a distinguished road
7psi is within the comfort zone for a stock T2 setup... NOS would still be much easier/cheaper, lol.
You may get up to 200whp NA w/ the 4 port irons a big enough SP, but its a stretch... good luck and keep us posted though!
Defined Autoworks hit 216whp on a dyna-pak using a 13B-RE setup for N/A.
farberio is offline   Reply With Quote
Old 12-17-2008, 12:21 AM   #18
but it's not a stock turbo......7psi on a diesel turbo isn't teh same as a stock turbo.
If anything the NItrous might help him spool it easier but asking to guess power is crazy.....
Do finish up andpost results though...I wanna see when you see full boost.
Old 12-18-2008, 08:50 AM   #19
88moneypit
88moneypit's Avatar
88moneypit is on a distinguished road
would a stock t2 turbo work alot better?
88moneypit is offline   Reply With Quote
Old 12-18-2008, 09:03 AM   #20
A hybrid stock turbo, or an eBay T04 manifold with a T04 turbo would be better than the diesel turbo.
Old 12-18-2008, 01:01 PM   #21
+1
Old 12-18-2008, 02:34 PM   #22
88moneypit
88moneypit's Avatar
where can i come across a 12a turbo header?
Old 12-18-2008, 03:41 PM   #23
I am not sure on this.... If he is using a 13B setup with 12A plates, will he need a 12A or 13B manifold setup?
Old 12-18-2008, 03:52 PM   #24
farberio
Turbo motors don't have headers.
Old 12-18-2008, 03:54 PM   #25
farberio
The lower manifold would have to be 12A, if he is using 12A plates it must be a 12A keg. So anything else wouldn't fit on the motor but the 12A size parts. It may be adapted to work with some sort of 13B upper intake though. It could also have been custom.
Old 12-18-2008, 03:59 PM   #26
I think he just chose the wrong choice of words...Not really thinking headers :wink:
Old 12-18-2008, 04:09 PM   #27
classicauto
crash auto?fix auto
classicauto's Avatar
The plates won't matter - the housings are where the main difference (width wise) is at.
If there's 13B rotors/housings - 13B width
If there's 12A rotors/housings - 12A width
Old 12-18-2008, 04:11 PM   #28
All I know from what he has said on another site is it supposed to be a 13B with ported 12A plates idk lol
Old 12-18-2008, 08:03 PM   #29
MEASURE!!
If it is a bastard engine, and requires a 12a exhaust manifold, he might be in for some fab work. Get a 12a exhaust flange (mazdatrix or RB sells them) get a cheap T04 manifold off eBay for an FC or FD(+/-$100) hack off the flange and start to pie cut and weld!!
Genius!
Old 12-18-2008, 08:08 PM   #30
Thats what I was thinkin DJ just wasnt sure....
