Old 11-29-2008, 09:33 PM   #16
fire85gslse
fire85gslse's Avatar
more Don, we need more!!!!!!!!!!!!
Old 12-02-2008, 08:05 PM   #17
sk8world
600rwhp club member.
sk8world is on a distinguished road
show'em those shinny new wheels!
sk8world is offline   Reply With Quote
Old 12-02-2008, 10:36 PM   #18
Teenwolf1393
Teenwolf1393 is on a distinguished road
good i dea with the vent. i would never put anything there. nothing better on a hot day than cold ac directly on your junk
Teenwolf1393 is offline   Reply With Quote
Old 12-03-2008, 05:22 PM   #19
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
I remember your car from DGRR 2005. Guess who's smoke screen this is...
impulsive-RX7 is offline   Reply With Quote
Old 12-03-2008, 05:37 PM   #20
I remember that
Old 12-03-2008, 06:22 PM   #21
HDP
HDP is on a distinguished road
If the weather is nice this weekend, I will snap a few pics.
HDP is offline   Reply With Quote
Old 12-03-2008, 06:23 PM   #22
HDP
Hopefully at DGRR 2009 the only smoke I leave will be tire smoke...
Old 12-08-2008, 06:52 PM   #23
HDP
Ok, I was able to snap a few pics of the car yesterday while the weather was nice (but cold). Not many changes to the exterior other than Rotary Extreme plateless 99 spec polyurethane bumper cover and the 18x8/18x9 ASA wheels.
Old 12-08-2008, 07:31 PM   #24
HDP
Engine mods
I made many changes with the look and performance of the engine. I will try to go in depth with the modifications made.
Old 12-08-2008, 07:42 PM   #25
HDP
I decided to go with a smaller battery (51R) to allow more room for the intercooler. I made a custom tray that mounts in the same location as the stock piece. After looking at the tie-down brace installed, I decided I will make another one to match the strut brace.
Old 12-08-2008, 07:52 PM   #26
HDP
While keeping the CAI I had, I wanted to have the filters permanently match the color of the blue used for the brake calipers, strut brace, and other accents. I used RIT navy blue dye to get them as close to the color as I possibly could.
Old 12-08-2008, 08:11 PM   #27
HDP
Along with the fuel pump upgrade, I had to upgrade the rest of the fuel system as well. I installed the fuel pressure regulator on the front of the UIM where the stock boost control solenoids were mounted. I had to fabricate a bracket to mount the FPR to one side in order to install the fuel pressure sensor. I also upgraded my fuel injectors to provide adequate fuel for my power level goal. Thanks to David Garfinkle, I was able to mount stock 850cc in the primary rail and 1200cc in the secondary. To get everything flowing smoothly, I opted for -6an fittings and braided stainless hose connected to the hard pipes at the fire wall.
Old 12-08-2008, 08:35 PM   #28
HDP
I also used Dale Clark's method for rewiring the fuel pump but I added my personal touch to it. After reading Dale's write-up and after examining everything, I decided to use one of the empty fuse holders in the stock fuse block to mount the fuel pump fuse. I used fuse terminals from a junk car (Mazda MX6) which is the exact match to that of the 7 and soldered it to the existing wire (see Dale's write-up for detailed directions). I pushed the fuse terminals into the fuse block and inserted the 20A fuse. I still need to label the cover for the new fuse.
Old 12-08-2008, 09:05 PM   #29
HDP
I ported the wastegate on my 99 spec twins using a dremel tool. It was easier than I thought it would be. Not sure the exact size I ported it, but I left about 1/16" for the wastegate door to close on. Since the R1 didn't come with cruise control, I mounted the HKS Twin Power on an old cruise control module bracket I got from a forum member (can't remember who it was).
Old 12-08-2008, 09:09 PM   #30
HDP
More to come... stay tuned.
