Old 11-23-2008, 05:26 PM   #1
fire85gslse
fire85gslse's Avatar
My 38K mile 93 SSM build
Ok guys and gals, a lot time planning for this day and it has finally come. I have owned the car for a bit over a year now. Bought it with 36K on it and well really have not driven it due to this work not being done.
My stock 93 SSM with 38k stock miles getting some work to make her last longer. Keep in mind I am not looking for HP but more dependable good power.
Once complete here is what will be done and staying Sequential. I will be trying to take pics of everything done and will be posting them.
So first to come....... my car in stock trim currently with:
SSR rims
Front cross drilled rotors
Petit AST - coming off going AST delete
New Poly motor mounts
Stainless Steel Brake lines
Eibach springs
99 Spec rear lamps
RB single tip cat back
Xcessive alum oil pan - Coming off going back to stock
Old 11-23-2008, 05:35 PM   #2
fire85gslse
Whats to come:
AST removal
Alum Radiator
Turbos ported and worked to keep my sequential
rats nest to be thinned out
coils relocated
cerma coated UIM, LIM with block offs
wiring harness to be thinned out and cleaned up
some water ports to be tapped off instead of just blocking them
TB to be worked a little
Garfinkle Motor works torque brace
Garfinkle Motor works oil pan brace
SR Motor sports SMIC
Greddy piping and elbow
1300 cc injectors
Efini cross over pipe
greddy boost controller
Power FC with commander
Wide band
down pipe
mid pipe
Beck/Arnley clutch kit
ETC............
alot of cleaning and small work that will be posted
Old 11-23-2008, 05:37 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Dang, 38k miles? Very nice. I like what you've got planned too.
Old 11-23-2008, 05:45 PM   #4
fire85gslse
ok here are some beginning pics:
Motor getting ready for removal.
Note the second pic on the driver side frame rail from where the battery sits.hard to get to area to keep clean. Well I will have to clean that up before the motor goes back in.
Old 11-23-2008, 05:53 PM   #5
fire85gslse
pictures of motor out and the frame rails painted in a black bed liner coating to help with rust/scratches. There was a seem that I followed to keep it uniform on both sides.
Time to replace every water hose under the hood (those that I will be keeping) all gaskets, studs/nuts on turbos and some other small odds and ends. Ray at Mazda sent me a box of goodies for almost $700 needed to do this work.
Old 11-23-2008, 06:04 PM   #6
fire85gslse
Turbo work
Here are some before pictures once the turbos were pulled off. See all the cracks and where the gasket sits. Now to basically gasket match the turbos and that will help with some cracks. The others will have to be welded.
Old 11-23-2008, 06:13 PM   #7
great condition car!
Old 11-23-2008, 06:39 PM   #8
fire85gslse
Turbo worked performed by Garfinkle Motor Works (Thanks David)
You can see the cracks have been welded, some grinding has been done, and see the black spots in the flat surfaces (low spots due to warping). Those will be resurfaced to get some/most of that taken out.
Here are those pics
Old 11-23-2008, 06:58 PM   #9
fire85gslse
more on turbo work (Garfinkle Motor works)
Old 11-23-2008, 07:08 PM   #10
fire85gslse
more pictures of turbo work done by Garfinkle Motor works
Old 11-23-2008, 07:16 PM   #11
fire85gslse
pics
Old 11-23-2008, 07:19 PM   #12
fire85gslse
My cheap Radiator that I had to modify the shroud to fit. Had to use bolts and nuts to mount it on the bottom and had to open up the holes on the shroud top sine it all was not lining up perfect.
Then I had to notch the shroud since the upper tube was at a different angle over the stock location (seen in the next group of pics).
If you buy one of these keep in mind that its not a direct drop in nor does it have a drain or a line for the AST.
If I would had known about this up front I would have spent more for the right one.
But again $150 for this was not too bad even with the mods I had to do.
Old 11-23-2008, 07:35 PM   #13
fire85gslse
more radiator pics.
Had to remove the name on it
Old 11-23-2008, 07:45 PM   #14
fire85gslse
Motor sitting waiting for more work and harness to be complete.
Here is my motor sitting there now with the turbos back on.
Old 11-23-2008, 09:15 PM   #15
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
See you decided to pull the motor. Makes the work you are doing a lot easier. David is the turbo porting master. Work looks great.
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
