Old 11-01-2008, 10:47 PM   #1
HellBent
Evil and Proud
HellBent's Avatar
HellBent is on a distinguished road
GSL-SE issues
Alright,So the car is getting spark,is getting gas.
AMF is plugged in.
Car will turn over all day long but will not catch and run.
Car was only moved 10ft and parked, i have been through the un flooding process twice (just to be sure) motor has compression.
any ideas??? or pointers?
going to die young and leave a good looking corpse and a mangled seven
HellBent is offline   Reply With Quote
Old 11-03-2008, 10:18 AM   #2
Kentetsu
Kentetsu's Avatar
How did you determine that she's getting gas? Have you confirmed that the injectors are firing?
What procedure did you use to de-flood? You might want to try squirting some Seafoam into the spark plug holes, then trying again. That will usually deflood any rotary in short order...
Old 11-03-2008, 10:25 AM   #3
SpooledupRacing
Guest
Posts: n/a
pull the fuel pump fuse (BOTH OF THEM from the strip on the drivers fender)
pull out the plugs and crank the engine over for atleast 10 seconds. do this a few times till there is no more misting comming out of the plug holes.
add a touch of engine oil into the leading plug holes (both rotors)
put the plugs back in (make sure they are not wet, clean with a lighter)
put the fuses back in and crank it over
that should help deflood it.
Old 11-03-2008, 06:16 PM   #4
HellBent
Evil and Proud
HellBent's Avatar
Thank for the input, i will post info and a few pics of my baby
Old 11-03-2008, 07:01 PM   #5
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
Make sure your spark plugs are not fouled as well.
impulsive-RX7 is offline   Reply With Quote
Old 11-04-2008, 04:02 PM   #6
HellBent
Evil and Proud
HellBent's Avatar
Whole car has everything sitting here for a full tune up, the car has a 2nd gen fuse block,so the EGI fuse is a easy thing with un-flooding as well as removing the lower plugs.
Old 11-04-2008, 09:17 PM   #7
SteveO
SteveO is on a distinguished road
Check, check, and recheck your fuse blocks. Pull them and check all the connections. (Interior and under the hood) I had the same problem when I had my SE and it was the fuse panel wiring.
A little electric cleaner and a wire brush fixed the problem.
SteveO is offline   Reply With Quote
Old 11-05-2008, 05:02 PM   #8
HellBent
Evil and Proud
HellBent's Avatar
All fuse block fuses and under dash fuses checked, woke up kinda late and had a girl over, will do the full tune up during the day tomorrow.
Old 11-06-2008, 06:45 PM   #9
HellBent
Evil and Proud
HellBent's Avatar
Ok the full tune up has been done, everything checked. Found one of the wires from the coil to the distributer had a cooked,and broken clip that goes into the coil.
Car will turn over all day long but STILL will not catch and run.
Motor has GOOD compressions numbers.
Ive gone over everything i can think of, and nothings working out..
anyone want to come over? i got beer, food and can throw ya some cash for gas...lmao..
This is my DD and ive been FUCKING STUCK AT HOME OVER A WEEK!!! AHHHHH!!
Old 11-06-2008, 06:50 PM   #10
main relay? I think everything is the main relay. Maybe the coils aren't getting juice?
Old 11-06-2008, 07:08 PM   #11
HellBent
Evil and Proud
HellBent's Avatar
Well the plug wires are getting spark, trust me.. i cooked a finger tip.
I will throw on a spare set of coils tomorrow, just to see if it helps at all..
This is starting to piss me off.
Old 11-06-2008, 07:09 PM   #12
the good thing is that if you beat on the GSL-SE it won't call the cops.
Good luck man. Are you sure you're getting fuel and no vac leaks are present?
Old 11-06-2008, 07:16 PM   #13
HellBent
Evil and Proud
HellBent's Avatar
This is true, but my neighbors might call them for me acting crazy.
Old 11-06-2008, 10:00 PM   #14
Kentetsu
Kentetsu's Avatar
Try the Seafoam...
Old 11-07-2008, 03:21 PM   #15
HellBent
Evil and Proud
HellBent's Avatar
Picked up some Seafoam, and its raining!!! and my other project car is in the garage! *fuck fuck fuck*
