Old 10-28-2008, 02:20 PM   #16
Short shifter or Short Throw shifter Ted?
You know there is a difference, and need to be specific.
Also, all the points you make (other than the sequential set-up) can be traced back to driver error.
The point of a short throw shifter is not to shift faster, but lessen the distance the shifter needs to physically move to change gears.
Old 10-29-2008, 10:07 PM   #17
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Originally Posted by Max777 View Post
Well, I would do that, but after talking with Justin Pawlak (Pro drifter who drives an FC3S) a short throw shifter seems to put more wear on the transmission, and seeing that I have 140K on mine, I dont want to risk it.
Also, just as a follow up on this, I found the bushing, a company called MMR makes it:
http://mmr-direct.com/catalog1/RX7FC/index.htm
Interesting, does anyone know if this bushing will fit in an S4 tranny? My Short throw rattles a bit and this would be a quick, painless fix.
1988 GXL
Old 10-29-2008, 11:33 PM   #18
as far as I know, that bushing is the same, because I just replaced bushings on my friends S4 and my S5, and the hole looked exactly the same down there.
