Old 10-25-2008, 01:38 PM   #1
iHEARTfcs
iHEARTfcs is on a distinguished road
s4 NA water treatment hose?
I want to do the water treatment on my S4 NA
but I don't know which hose to use.
Help please
iHEARTfcs is offline   Reply With Quote
Old 10-30-2008, 07:33 AM   #2
RotaryXperiment
RotaryXperiment is on a distinguished road
u can chose the to put a hose on the really big vac nipple on the uim or use the hose that comes of the master cylinder.
just dont suck all the water in right away, do it little by litlle while giving it gas
RotaryXperiment is offline   Reply With Quote
Old 10-30-2008, 08:02 AM   #3
SpooledupRacing
Guest
Posts: n/a
Here is what I have done (effectivly)
USE SEAFOAM
follow the hose that goes from the brake booster accross the back of the firewall then returns to rubber and goes to the uim
pull the hose off the metal line and pour in 1 can of seafoam
shut the car off wait 5 minutes
start the car up and go drive the piss out of it until the seafoam is gone and the car stops smoking..
Old 10-30-2008, 09:19 AM   #4
USE SEAFOAM
Using that hose will only get the rear rotor. You need to use the location that feeds both the front and rear rotor at the same time. This location is from the MAP sensor located on the passenger side strut tower.
Old 10-30-2008, 09:23 AM   #5
SpooledupRacing
Guest
Posts: n/a
no that will toss it into the uim which will get it distributed to both housing. (this was found to be true after I tore my engine down)
it may not get distributed evenly but it does the trick.
