Old 09-25-2008, 05:14 PM   #1
Jeff4764
Jeff4764 is on a distinguished road
compression?? odd readings
ok, so i have an 87 n/a, ive explained this problem before... It starts fine when its cold, but once it warms up it has a hard time starting and sometimes wont even start. I was told to check compression so i bought a tester, (didnt remove schrader valve, just held in relief valve) the pulse is are very even steady pulses and all read the same. Heres the problem, its reading 50 psi every time.. But i was told if there steady and even pulses the compression is fine.. can someone give me some insight.. maybe a different problem the compression
Jeff4764 is offline   Reply With Quote
Old 09-25-2008, 05:18 PM   #2
50 is too low. Are you sure you tested it right. That's crappy compression. Normally anything around 80psi means your motor is dying.
Old 09-25-2008, 05:22 PM   #3
Jeff4764
im pretty sure i did, i tested both trailing, and pulled the injector and egi fuse and held pedal to floor while trying to turn it over. but if it was bad would the pulses be even
Old 09-25-2008, 05:54 PM   #4
If it was tested correctly than 50psi is toast. Rebuild time.
I suggest Rotary Ressurection.
Old 09-25-2008, 06:07 PM   #5
87turbo_turtle
Rotary Chic
87turbo_turtle's Avatar
87turbo_turtle is on a distinguished road
sounds like its time to rebuild
Turtle
Yes I am a girl and I will kick your butt.
Prove yourself.
87turbo_turtle is offline   Reply With Quote
Old 09-25-2008, 06:13 PM   #6
Jeff4764
I do believe you guys, but does it sound like i did it right?? and would the pulses be even if compression was bad? could it be in the intake? I have no idea.
Old 09-25-2008, 06:14 PM   #7
Jeff4764
and if it was 50 psi would it even start cold.
Old 09-25-2008, 06:17 PM   #8
Take a video of both rotors being tested. 50psi is too low, whether or not the pulses are even (your apex seals intact).
Old 09-25-2008, 06:25 PM   #9
Just because the apex seals are there, does not mean they are efficient at sealing anymore.
Heat causes expansion, expansion lowers compression.
Old 09-25-2008, 06:36 PM   #10
Jeff4764
ok I can do that and post it tomorrow. But does it sound like i did it right...
I tested both rotors on trailing side. the compression tester fitting screwed into the spark plug hole and i pulled both the inj. fuse and the egi. fuse. I had my girlfriend get in the car and push the pedal to the floor, and cranked it for about 10 seconds while i held the pressure relief valve in and got a steady reading of about 50 psi. I will take video, and if you guys can check it out tomorrow and give me some input that would be awesome.
Old 09-25-2008, 06:37 PM   #11
classicauto
crash auto?fix auto
classicauto's Avatar
Was the engine warmed up when you did the test? Otherwise everything else sounds pretty good as far the tests execution is concerned.
Although those are low numbers even for a stone cold engien that is in decent shape....
Old 09-25-2008, 06:42 PM   #12
Plus, you can drive it until it can't hold compression. Just don't expect it to go anywhere, fast.
Some people add a bit of premix to raise compression too. If you can't get it rebuilt soon then I'm sure others will chime in with ways to help the motor last a little bit longer.
Old 09-25-2008, 10:08 PM   #13
You're doing it correctly. 50PSI is fine for checking the apex seal condition, now you need true compression value of the rotor. Do not hold the relief valve and you should get the max number on the compression. I bet you're going to be getting above 100PSI, just a guess though.
http://www.aaroncake.net/RX-7/blown.htm
Old 09-26-2008, 06:58 AM   #14
Jeff4764
If i hold the relief valve it will just keep bouncing to 50 psi. If i let go of the relief valve it will bounce a fewtimes and stop at about 95 psi. so if what your saying is right then i am a happy camper.
Old 09-26-2008, 07:32 AM   #15
Happy that you have compression, but sad that you still have hot start issues.
