Old 08-12-2008, 07:14 AM   #1
High idle issues: revisted
okay, i still have not found a good solution to my high idle problems and its driving me up a wall.
Here is what the car is doing:
Generally in the morning, ill start the car, it revs high for the 3k warm up, i tap the throttle it goes down to about 2000 rpms. During the course of driving to work, it usually tried to idle between 2000 and 2500 rpms. During lunch time i will choose to idle between normal and 2000 depending on the day. I have watched it idle at about 800 rpms fine. Then just start climbing to 2000 or higher.
What sensors, if not reading properly, can cause such idle issues? I have also noticed the car is running richer (more pops out of the exhaust) and i am thinking they are related.
Old 08-13-2008, 02:36 AM   #2
Boostmaniac
Possible vacuum leaks can cause this.
Or you have a massive bridgeport and you just don't want to say that
Old 08-13-2008, 06:50 AM   #3
could a bad BAC cause it?
Old 08-13-2008, 10:40 AM   #4
Boostmaniac
I guess it could, but it doesn't seem likely. Have you checked for leaks yet?
Old 08-13-2008, 11:30 AM   #5
i have but didnt find anything. I am going to look the TID over off the car though
Old 08-14-2008, 05:55 AM   #6
It sounds like the cold start thermowax is sticking, or the TB itself is sticking.
Old 08-14-2008, 07:14 AM   #7
would that cause the idle to increase while its sitting though? i was under the impression the thermowax doesnt go about 1500 anyway. Hmmm...well i could remove it and see what happens.
Old 08-14-2008, 10:26 AM   #8
TehMonkay
I'd probably say its the thermowax as well. I was having the same issue i'm almost sure of it.
Old 08-14-2008, 11:18 AM   #9
alright well i will try to remove it this weekend and see what happens.
Old 08-14-2008, 12:07 PM   #10
Boostmaniac
I have had a TB stick slightly open, about .5mm and that caused one HELL of a high idle.
Check thermowax, then see if you can actually shut the TB with your hand to drop the idle. If not, let us know.
Old 08-14-2008, 10:03 PM   #11
Try this for a test...
Stick your foot under the gas pedal and lift up.
Does the idle want to drop?
If it does, then it's most likely a sticking TB.
Remove TB and shoot an entire can of brake cleaner or carb cleaner into the bores to clean all the crap out.
Old 08-14-2008, 10:04 PM   #12
Wait, I just taught of something really obvious...
Check the throttle cable tension...
DOH.
Old 08-15-2008, 02:03 PM   #13
this doesn't effect it
Old 08-15-2008, 02:04 PM   #14
DOH.
ill see if i can loosen the cable and start it up
