Old 08-08-2017, 07:59 AM   #16
infernosg
IT'S ALIVE!
infernosg's Avatar
Yep, as everyone has said the FC oil cooler is considered to be one of the best. I wouldn't worry about it unless you're having problems. If you're that concerned you can do what I did and make better ducting for the front of the car. In factory form air can pass over the oil cooler. I made a duct out of aluminum that divides the air coming in from the front of the car:
Google Photos has been weird so let me know if the image doesn't work.
I do recall reading some Improved Touring (IT) guys running dual FC oil coolers in series/parallel, but that seems like overkill to me.
Old 08-08-2017, 09:36 AM   #17
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Wanna make me one of those? I assume you are using that with the stock front bumper?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 08-08-2017, 10:32 AM   #18
project86
project86's Avatar
Originally Posted by FC Zach View Post
I'm glad it's already been mentioned that you'd be downgrading. . even if you did a twin set-up (aside from the extra failure points and places to leak, like Pete said), the two combined still wouldn't suffice when compared to the OE part. Especially without going the extra mile to build duct work to each to even have a fighting chance.
For what it's worth, (IIRC) my oil temp is typically ten or more degrees cooler than engine temp when driving.
I'm really glad to know that the stock one is so good. I guess I'll just look into getting braided lines for it and call it a day.
'90 GTUs
'10 Toyota Prius
Old 08-08-2017, 04:17 PM   #19
If your factory lines are in good shape, and not leaking, don't replace those either.
Old 08-08-2017, 04:29 PM   #20
project86
project86's Avatar
But im going to.
'90 GTUs
'10 Toyota Prius
Old 08-08-2017, 11:13 PM   #21
FC Zach
FC Zach's Avatar
But the braided lines look better
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-09-2017, 06:43 AM   #22
Pete_89T2
Pete_89T2's Avatar
But im going to.
Why? Don't fix what isn't broke or you'll be back here with another problem
There's nothing wrong with the stock lines, and if they are in good shape, they will remain leak free and work as well as any aftermarket lines you could buy or build yourself for many years. I would just give the stock lines a very thorough cleaning and inspection, and go from there:
1. Are the crimp fittings corroded excessively (more than just a little surface rust), and if you try to rotate the crimp fitting around the hose, does it rotate at all relative to the hose? If answer is NO on both, stock lines are good.
2. Is the rubber hose material still pliable, with zero evidence of swelling or any unusually brittle/hard or mushy/soft spots that you can feel when you squeeze the hose anywhere along its length? If it passes this test, the stock lines are good.
Old 08-09-2017, 07:12 AM   #23
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I agree to disagree on this one. The lines are old enough at this point that its worth the money to get new ones. And the RB ones do look purty!
Old 08-09-2017, 12:52 PM   #24
project86
project86's Avatar
I'll at least check them. If they aren't leaking then I wont prioritize. I can tell you whats not leaking though.. my oil pan....
'90 GTUs
'10 Toyota Prius
Old 08-09-2017, 04:10 PM   #25
I have dual 19 row Setrab coolers on my FD and I've seen as low as 109F in the winter and usually about 140-150F in the summer. WAY too cold, I know. But I tested the thermostat and it works, and I made sure it was mounted to flow correctly. Not sure what the deal is.
I was always under the impression that the FC cooler wasn't that great. Good to know otherwise. I'll leave it on my TII (that I haven't started building yet).
Old 08-10-2017, 08:37 AM   #26
40 year old lines on both Cosmo's holding strong.
The only issue I have with aftermarket cooler lines (like RB) is they rely on an adapter. Just another potential failure point. And some people have been unfortunate enough to strip or crossthread trying to install them.
Old 08-10-2017, 09:13 AM   #27
project86
project86's Avatar
Are YOUR 40yr old lines still holding strong?
'90 GTUs
'10 Toyota Prius
Old 08-10-2017, 09:28 AM   #28
Thankfully YES!!!
Too well. Ask the wife..
Old 08-10-2017, 09:42 AM   #29
t_g_farrell
Waffles - hmmm good
Ok, but you may want to get some replacements before DGRR next year, so when it blows on the mountain you can swap in the new ones. Just sayin'.
If you were to cut one in half and squeeze it you will see that its swollen and cracking apart.
Old 08-10-2017, 09:44 AM   #30
project86
project86's Avatar
I'll probably replace them before then. I replaced them promptly on my first FC and never had any issues. I dont anticipate an issue with doing SS lines this time either.
'90 GTUs
'10 Toyota Prius
