#181 |
Rep Power: 20 ![]() |
So I swapped the clutch and installed the rebuilt transmission this weekend. The Centerforce Dual Friction I removed appears to still have a lot of life left on it, is there still a market for these? I'd sell it cheap if there's any interest in it.
I am waiting on oil I ordered from my AmsOil guy and an output shaft seal from Atkins Rotary to arrive so I can button everything up. I tried getting this seal locally from Oreillys but for whatever reason neither of the manual or auto seals were correct. . They couldn't cross-reference it either but luckily Atkins pulled through ![]() I had to remove the fancy coil mount kit to remove the long starter bolt and as I laid it to the side I felt something protruding from one of the coil-to-plug adapters. . here's what I found: One of the detents for the plug weren't seated completely and the bad connection caused it to get hot enough to melt almost completely through the plastic housing. ![]() I'm no longer going to be using the COP adapters and will be replacing them with tailored wired. I'll still use the coil mount, just not as it was intended. Since the power harness was mostly disconnected, I completely removed it with hopes of replacing it with a new harness (mine is in very rough shape). I contacted Chris Ludwig to see if he can do this, if not does anyone have any recommendations on where this can be built or purchased?
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#182 | |||
Rep Power: 10 ![]() |
![]() Quote:
#183 | ||
![]() Fixed I had extra MSD Super Conductor wire from previous builds but unfortunately had to scavenge from a new box for 8 boots and terminals![]() Quote:
Trans seal arrived while asleep today and oil picked up from Amsoil guy, will hopefully get this done in the morning. ![]() Before going to sleep today I installed my shifter and ran through the gears but couldn't get it to go in fifth or reverse I don't recall the engine having to be running to go in these gears. . could this simply be gears not aligned to allow the hub to slide in position? ?
#184 | |||
![]() Quote:
![]() Too bad they didn't live longer. I would've been curious to see if they made a real world difference in power on the dyno. Ironically.... well.... was it a leading or a trailing that took a shit? Quote:
#185 | |||
![]() Quote:
man what a last couple of days! Nothing is going right, I almost fell through the ceiling Sunday afternoon! Got a hole in the bedroom to prove it LOL. . . This too shall pass!
#186 |
IT'S ALIVE!
Holy crap on the COP adapters! I guess it's a good thing I never worked out a mounting scheme. Hopefully this is just indicative of the "variation" of the IGN-1A coils and not Peter's work. I'll stick with my coils mounted on top of the engine for now.
#187 |
I believe it is a coil issue, I had to modify the adapters to snap in place.
#188 |
That's so unfortunate about the trans
Well shit, at least there's time and it's not 02:00 on Friday Morning the day before DGRR
#189 |
True
#190 |
Good news guys! ! I found the problem! The shifter housing spring loaded return and detent weren't assembled correctly and prevented the shifter from moving on that side. I took it apart and the lever shifted freely into both gears! It's beer thirty now!
![]() So happy I don't have to remove and replace another tranny
#191 |
WOOT for easy fixes! If only my trans were that easy to fix
#192 |
I'm glad it was an easy fix, sure did save me a lot of headache! Now the search continues for the power harness. Oh yeah, I still gotta fix that alternator issue too.
#193 |
I just keep laughing because I compare it to my todo list for DGRR and it's like....
![]() RX8 - Pull engine and blah blah blah blah exhaust blah blah blah blah rear tires blah blah blah blah new windshield blah blah blah blah RX7 - Swap rear diff blah blah blah blah swap tranny blah blah blah blah new driveshaft blah blah blah blah headlights blah blah blah blah DYNO!!!!!
#194 | |
Rep Power: 22 ![]() |
Blah blah blah I'm drunk Blah blah blah blah I'm about to get drunk Blah blah blah herp derp I'm working on Pete's FC
#195 |
