Old 07-22-2016, 06:05 AM   #271
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
While the sub frame is out I've been working on refreshing the suspension/steering.
Installed poly PS, control arm, and sway bar bushings.
[IMG]
New ball joint boots.
[IMG]
New inner and outer tie rods, and new steering rack boots.
[IMG]
New adjustable sway bar end links, and sway bar mounts as well.
[IMG]
Still need to sand blast/paint the lower control arms and install the new bushings.
Sexy!!! I've always wanted to pull/blast/recoat the subframe and stuff... I'm jelly.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-22-2016, 08:07 AM   #272
Your arbor press has enough throat to do the arms? Nice!
Now when are you dropping the rear subframe?
Originally Posted by hades View Post
Well that made me wet
No one wants to
Old 07-22-2016, 08:11 AM   #273
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
No one wants to
Well, I'd like to be able to appreciate the end results.. We'll put it that way
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 07-22-2016, 09:12 AM   #274
RXtacy
RXtacy's Avatar
I wouldn't say it's fun, but the end results are nice.
Negative, but I made my vice work.
I don't want to talk about it. I do have pillow balls and bushings that need to go in though
No one wants to
This.
More accurate
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-22-2016, 09:35 AM   #275
More accurate
Much
Old 07-22-2016, 09:42 AM   #276
RXtacy
RXtacy's Avatar
Why you facepalming me fool?
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-22-2016, 10:00 AM   #277
Moar parts going backwards
Old 07-22-2016, 10:25 AM   #278
RXtacy
RXtacy's Avatar
Ah true, but should be relatively minor. Don't have plans to drop the subframe, the diff bushings are already done. Just need to do the control arm bushings, and the pillow balls. I also have toe links and trailing arms on order, so we won't have to deal with those bushings.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-22-2016, 10:46 AM   #279
Ah, kewl.... was unsure how Treffeisenized you wanted to go with sandblasting and painting/powerdercoating the rear subframe
DON'T FORGET WHEEL LOCKS!
Old 07-22-2016, 10:50 AM   #280
RXtacy
RXtacy's Avatar
Yea I like the idea of dropping painting etc, but since no one will ever see it I'm not inclined to put in the effort if I'm honest
Would probably like to clean/paint the control arms though.
Word. Send me a text next week to remind me.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-22-2016, 10:57 AM   #281
Like I'm going to remember? Visegrip them bitches off!
Old 07-22-2016, 11:13 AM   #282
RXtacy
RXtacy's Avatar
If I even see you in the vicinity of my wheels with vice grips I'm going to punch you in the dick.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 07-22-2016, 11:35 AM   #283
Now we are getting kinky yeah?!?!?
I didn't say I was going to do it, I'm saying if you forget the wheel locks again, YOU'RE going the HAVE to do it
Old 07-22-2016, 03:11 PM   #284
chibikougan
chibikougan's Avatar
Just buy a smaller socket notch the locks and bang that lil socket on there take off wheel lock.
Old 07-22-2016, 03:12 PM   #285
chibikougan
Or just weld a damn Nut on the end..
