Old 05-06-2016, 11:58 AM   #91
The FTP's that I bought from DJ fell apart on me.... and they never really fit the bumper right anyway. I'm going to experiment with vac forming and try to make my own. Then throw some neon in there... it'll be phat yo
Originally Posted by project86 View Post
COME ON DJ!!!!! WHY YOU GOTTA DO BRI BRI LIKE THAT?
I don't sell junk. I fix it (or attempt to)
He didn't, they were mint when I got them.... it's that cheap japanese plastic
Damn right. And that was what? 5-6 years ago?
Old 05-06-2016, 01:03 PM   #92
Something like that, yeah... I think it was the year of my rd trip... which was 2010
Old 05-12-2016, 06:57 AM   #93
project86
Can't.Make.Up.My.Mind.
project86's Avatar
I've been slackin'. Next plans are to put in the new trans cross member and poly mounts. I'll most likely end up doing that on sunday or monday. After that the fixing the leaky oil pan is on the list and while I'm down there doing poly motor mounts as well. Part of the hold up is being out of money haha. I need to find a job badly.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-12-2016, 07:45 AM   #94
project86
project86's Avatar
Also.. Id quickly like to revisit the idea of swapping miata gear set into the FC trans. Does anyone happen to know what kind of power that set up can handle? In doing all the mods to the car for the future i'd like to set things up as i go so that it will all manage the future goals of power.
'90 GTUs
'10 Toyota Prius
Old 05-12-2016, 08:43 AM   #95
infernosg
IT'S ALIVE!
infernosg's Avatar
I'd say about as much as the N/A RX-7 transmission. That is, not too much. I've seen both transmissions completely disassembled and I didn't see anything that would indicate the Miata gear set is any stronger or weaker. That's not to say there aren't any differences. I used a gear set from a '96 Miata and I noticed the following differences versus my stock '89 transmission:
-Second gear has two synchronizers
-The reverse gear has a helical cut
-Small casting differences in the bearing plate
-No gigantic weight on the output shaft
I used the front (bell), gear (middle), and rear (tail) housings from the RX-7 transmission. The bearing plate and everything else were from the Miata transmission.
Old 05-12-2016, 10:52 AM   #96
Ran a TII engine in front of my NA trans for 5 years of dragon slaying and spirited driving with absolutely no problems whatsoever. When I fragged that motor, the trans went to Charles, which he still might have around (maybe in Sheba).
So, like most RX-7 issues, its usually the driver at fault.
Old 05-12-2016, 11:17 AM   #97
That would be the truth.
We maintained a metric fuck ton of ITS cars up at Speed1. Teams would go through 3+ trannies a season and the failures were ridiculous. As in stripping the teeth from the gears.
Once we started cryo'ing the trannies they would last all season and just need new syncro's in the off season... and the fluid would drain gold It was fucking hilarious.
Old 05-12-2016, 01:03 PM   #98
project86
project86's Avatar
I guess i just got the idea in my head to do the miata gears swap and wondered how much power i could throw at it (maybe around 350whp max?).
That makes me not worry so much. I guess I could always do the TII trans. But as i said above ^^
So you think if i had the gears cryo treated id be ok even if i ran around 350whp? I mean I'm not gonna be tracking the car. Just spirited driving really.
'90 GTUs
'10 Toyota Prius
Old 05-12-2016, 02:29 PM   #99
I know you're asking Bri-bri, but in my opinion, the money is better spent elsewhere.
Like paint....
Old 05-12-2016, 04:48 PM   #100
project86
project86's Avatar
Like paint....
Really I'm asking whoever wants to answer.
As far as paint goes I'm still going back and forth about it. Not sure if I want to leave it Red or do a color change. Either way I'm gonna feel the need to pull the engine for the paint stage. It will really bother me if it doesn't look good under the hood too. And if I'm gonna go that far I might as well change the color.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 07:44 AM   #101
infernosg
IT'S ALIVE!
infernosg's Avatar
If you're not going to track your car the N/A transmission with Miata gears will probably be fine. ITS cars spend a lot of time at high engine speeds so even with less power they're putting more stress on the transmission. You could always look into a transmission cooler if you're still concerned. In my opinion it's still less expensive and confusing than having to deal with a turbo transmission in an otherwise N/A car.
Old 05-13-2016, 08:10 AM   #102
I suspect that it will handle it just fine
An n/a car would benefit more from the RX8 6 spd swap than a TII swap
I think if you cryo'ed the whole tranny you would never have a problem with it.
Like paint....
I tend to agree
Absolutely correct. Not to mention the 5.11 gears and Hoosiers that put way more strain on a tranny.
Old 05-13-2016, 08:14 AM   #103
project86
project86's Avatar
Even with the 350 hp number in mind? At this point my plan is to do a NA 3 rotor when its time to do the engine swap. Its what i really wanted originally with my old car (or an RE swap but i don't want to deal with turbo now). I guess I shouldn't have been so vague in the beginning with this question. So now its all out there.
Im probably really showing my ignorance now but why would it be a expensive/confusing to just swap a TII transmission in? Seems like that option would be less expensive than buying another trans and then having a shop swap the gears and mod the input shaft?
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 08:34 AM   #104
project86
project86's Avatar
Disregard my post above this then. You must have posted this at the same time i posted.
Ah i remember us talking about this forever ago. I know you were still kind of in the experiment stage though when we did. I really need to read up on gear ratios though... I know they are simple but i just don't know exactly what I'm looking at when i see the numbers.
I tend to agree
Paint is high on the list after I get the other small things worked out. Im planning to get a quote for it soon. I'd be more than willing to do it myself but i don't have a place to do the work. I don't really want to close my wife out of the garage but i may talk to her about it after i get a quote. I have a feeling the price to paint might motivate her to let me make a mess of the garage and buy a compressor. That being said however, as long as its been since ive painted anything a shop could certainly do it better than me at this point.
I guess what i could do is the body work portion of it and then trailer it to the body shop for paint. Although typically they don't like that sort of thing but ill probably ask about it when i go for the quote just to see what they tell me.
'90 GTUs
'10 Toyota Prius
Old 05-13-2016, 09:58 AM   #105
I disapprove. All rotaries should be turbo. Especially those with a displacement greater than 1.3L
I've been running the 8 6spd for a while. It hasn't proven itself all that reliable but people say they are weak, and I say they're ignorant and need a lesson in how TO FUCKING DRIVE A MANUAL TRANS!
To me a trans is weak when it can't handle the torque and teeth strip and shafts twist or break. When you over extend a shift hub and the detent balls pop out into a tranny spinning at 9k, can you really say the tranny's weak? not in my eyes. In that case you're a fucktard who needs to learn to shift properly.
That's what I plan on doing actually... that's what I did for the most part last time... although I rented the booth and shot it myself. Not sure I wanna do that again though.
