Old 03-15-2016, 08:30 AM   #211
RXtacy
RXtacy's Avatar
Not a lot to show, but have been making a lot of progress on the wiring tuck/relocation. I have removed all the erroneous wires that are no longer necessary and have re-routed the entire harness through the cabin. What I am doing is effectively inverting the U shape the harness originally takes out around the engine bay and sending it back through the cabin and under the bins. I will be mounting my battery in the bin, replacing the factory relay block and main fuse block with a bussman fuse/relay block (see below), and mounting the large factory fuse/relay block by the rear driver side shock tower. The entire front harness below will now be routed through the cabin and out of sight.
I have got the harness routed through the cabin currently and have extended all the wires that still need to go to the front (head lights, horns, turn signals, etc.). I need to extend the fuse/relay block wiring, mount the battery, and wire up the bussmann still. I have also fully deleted the air bag wiring.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-15-2016, 08:34 AM   #212
RXtacy
RXtacy's Avatar
I have also begun fabricating my WG recirc tubes. They are going to be really tight, but should work out nicely. Still need to finish the transition to the DP.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-16-2016, 12:30 PM   #213
rotarynerdette
Eggz
rotarynerdette's Avatar
rotarynerdette is on a distinguished road
Those welds have come a long way.
rotarynerdette is offline   Reply With Quote
Old 03-16-2016, 01:04 PM   #214
RXtacy
RXtacy's Avatar
You're telling me! Looking back is pretty embarrassing now, but you gotta start somewhere.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-16-2016, 01:12 PM   #215
chibikougan
chibikougan's Avatar
Well with the pro shops manifolds showing up looking much worse even when they half assed polish their undercut ... So I would not be embarrassed one bit!
Old 03-16-2016, 05:17 PM   #216
rotarynerdette
Eggz
That is very true, I can't even keep a steady bead yet.
Old 03-16-2016, 07:24 PM   #217
RXtacy
RXtacy's Avatar
Other than the basic mechanics of torch angle, and keeping the filler in the shield gas the biggest lesson I learned was fit up is key. Tight fit up makes a good weld. I found running beads repetitively on an aluminum sheet helpful in the beginning to get the basics, then just stick as much scrap together as you can get your hands on. Keep at it, it's a great skill to have
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-16-2016, 07:30 PM   #218
RXtacy
RXtacy's Avatar
Got a nice little care package from Glenn. Thanks for the hook up homie! Looking forward to seeing what this ECU can do.
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-16-2016, 07:37 PM   #219
chibikougan
Oooh interesting...
Old 03-17-2016, 02:57 PM   #220
rotarynerdette
Eggz
I just end up with aluminum penises
Old 03-17-2016, 02:57 PM   #221
rotarynerdette
Eggz
Did you see the new lastest parts they have sent out.... it gets worse.
Old 03-17-2016, 03:22 PM   #222
chibikougan
Haha the first thing I ever Tiged was an AL cock n ballz..
Old 03-17-2016, 03:28 PM   #223
RXtacy
RXtacy's Avatar
Ain't nothing wrong with that
This was the beginning of my practice sheet.
Who we talking about?
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-17-2016, 03:33 PM   #224
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
I'll make sure and bring along the MIG to DGRR and weld that on your balls for you ... seeing as you're so proud of it and all.
Old 03-17-2016, 04:10 PM   #225
rotarynerdette
Eggz
