#166 |
lol ditto
-75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month ![]() -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
#167 | |
Rep Power: 22 ![]() |
#168 |
Rep Power: 20 ![]() |
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#169 |
Which S4 harness you need? High or low imp injector harness/clips? I might have one laying around in the shop but I can't remember which it is.. I'll have to take a look lol...
#170 | |
Professional Stick Poker
edit: spent the day putting together a cardboard template so I can get a radiator ordered from Ron Davis Radiators. This trying to fit 10lbs of potatoes in a 5lb sack is getting a little tedious. ![]() Here are some pictures of my primary injectors and one of my better injector clips. Somebody should be able to identify them without having to go digging again. primary injectors by Kevin Frank, on Flickr injector clip 2 by Kevin Frank, on Flickr injector clip 1 by Kevin Frank, on Flickr
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 Last edited by GySgtFrank; 10-26-2015 at 05:59 PM. |
#171 |
OK. Since nobody can identify whether my injectors are high or low impedence by sight, I will need to go digging to find out again.
I wish I would write these things down. So, my exhaust parts showed up today. exhaust parts by Kevin Frank, on Flickr2 - 48" long straight pieces of 2"OD .120 wall tubing (The extra shorter piece is what I have left from my earlier adventures) 3 - 48" long pieces of perforated 409 SS tube (The ones in the cardboard tubes. I probably got more than I am going to need for this project, but they weren't that expensive.) 5 - 3" radius 180 degree mandrel bends (same tube as the straight pieces) 2 - 4" radius 180 degree mandrel bends (again, same tube as the straight pieces) 4 - SS Racing beat road race flanges 4 - Mild steel Racing beat road race flanges 5 - Exhaust gaskets for above flanges The only pieces that I should need to complete the exhaust system now should be SS wool for muffler packing, more hangers, aluminum sheet for heat shielding, and SS sheet to make the muffler cases. I am not too sure that I want to total up what the exhaust system for this thing is going to end up costing. :shudders:
#172 |
Looking forward to seeing how this comes out.
#173 | |
I dunno about those clips though... The offset key is a late-87 or 1988 model harness. I'm not an NA guy, but the offset key on a turbo FC means high-impedence. Finding those rectangle, off-set key fuel injectors might not be easy... If not, just clip them and use "Bosch" plugs to fit those low-impedence fuel injectors and just add a ballast resistor in the circuit. -Ted |
#174 |
Thanks Mike and Ted. I figured somebody would have the answer. It is going to be a while until I get to the injectors and wiring, now that I have the money for parts. I need to get the exhaust and cooling system done before I can move on to pulling the engine again. It needs to come back out so I can get the finish welding done and wire it up.
#175 | |
That's OK, because you can weld
#176 | |
#177 | |
I would assume low is in the 2-3 Ohm range w/ high being ~12. |
#178 |
You are determined to get me side tracked aren't you?
![]() My neighbor/landlord used my multimeter to test a 200amp line going to the house. The leads didn't survive and the meter seems to have lost it's mind. I guess I really need to buy a good quality multimeter again one of these days. Any suggestions on a good one? I've had enough of the cheapies that work a time or two and then you have to throw them away. Right now I'm trying to get my pipe bender stand fixed. Welding the crappy casters that I replaced on my wheel dollies to the stand so I can move the heavy bastage. I need it out where I can work on my perforated tubing.
#179 |
Gunny - Fluke if you have a big budget. They are worth it. But hot damn do they cost an arm and a kidney. The one I use for work lists around 800. You should be able to find a decent one in the 150 to 200 range.
#180 |
Good luck old man.
This is going to tear |
