Old 08-03-2015, 05:57 PM   #46
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
Originally Posted by 88turboii View Post
doesnt defined auto make a oilpan that clears? or too pricey?
they modify the back of the stock 20B oil pan to clear the FD subframe (and decreasing oil capacity. They do not do any modifications to the front of the oil pan where the sump tube is. and from my previous experiences of doing business with them, I would rather just not deal with them again.
My plan is to leave the stock oil pan unmodified and to cut my subframe and modify it to fit around the 20B pan. really it's just cutting out one section and welding a new cross bar further back... i probably should do this before i re-install the front lower control arms... since i have to swap out subframes anyway...
Old 08-04-2015, 12:37 PM   #47
silverfdturbo6port
500hp club
silverfdturbo6port's Avatar
silverfdturbo6port is on a distinguished road
Either way you do it your gonna have to fabricate. Best to mod the oil pan unless you really know what your doing with the subframe.
Since I moved my engine back 3" I made a custom subframe and oil pan
And if you decide to modify the steering rack mounting in any way make sure you dont have any bump steer with the final product.
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew
20B 20BEEST FD
23A 4 rotor Long gone
72 rx3 drag machine
silverfdturbo6port is offline   Reply With Quote
Old 11-23-2015, 12:22 PM   #48
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
i did modify a stock subframe. I simply cut out the rear "cross bar" and replaced it with a smaller bit of square stock. i'll snap some pics while the engine is out for the car to get the bay painted...
so, this past weekend I was able to get the engine test fit again with the modified subframe, depowered steering rack, stock 20B oil pan (with banzai racing oil ban brace), exhaust, trans, and intake setup.
now everything clears a stock hood... without the fancy air box... so i'm running open trumpets and need to figure out filters for them. At this time, the car is stilling with a full drive train except for drive shaft and powerplant frame.
one thing to note are that the header barely touches the subframe so when i pull the engine off and before the car is sent off to get the bay painted, I'll need to do a little massaging of this area. need to just notch it to clear more.
otherwise, i'm happy with the clearance the steering rack has below the engine... and if i wanted about another 1/5'' of clearance from the hood, I could get some 2.4'' tall engine mounts (instead of the 2.6'' I have now) And dropping the engine lower would definitely require me notching for the header on the subframe. I'm also having to look at other options if i want to run a front strut tower bar, the one that came with the car doesn't clear the trumpets.
as before, next steps:
  • engine bay painted
  • header coated
  • massage/notch subframe for header
11 pics added to the album
Old 11-23-2015, 01:35 PM   #49
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
You know you can't keep using the id lt1_fd3s once this is done, right? I mean
you will now be 3rtr_fd3s or something.
Or just poor!
Looks like progress, anyway you look at it. DGRR 2016 for it?
Old 11-23-2015, 01:40 PM   #50
almoststockfc
almoststockfc's Avatar
I like your scooter. Its a good size for you
-75 RE_W_PU -
Old 11-23-2015, 09:09 PM   #51
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
might have to see about getting my id changed to 20b_fd3s or something after she's done...
Old 11-24-2015, 06:40 PM   #52
rgould
Rotary Non-conformist
rgould's Avatar
rgould is on a distinguished road
looking good will be looking for it
rgould is offline   Reply With Quote
Old 04-09-2016, 02:33 PM   #53
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
How's this project coming along?
Will it be making an appearance at DGRR?
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 06-10-2016, 10:55 AM   #54
tomsn16
tomsn16 is on a distinguished road
Yea Tray....we need an update....anxious to see it with new paint.
tomsn16 is offline   Reply With Quote
Old 05-28-2018, 04:55 PM   #55
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
it finally ran last night
Old 05-28-2018, 05:15 PM   #56
chibikougan
chibikougan's Avatar
Old 05-29-2018, 09:35 AM   #57
t_g_farrell
Waffles - hmmm good
Nice! Sounds good too! Can't wait to see it.
Old 05-29-2018, 10:51 PM   #58
FC Zach
FC Zach's Avatar
I cant wait to see it either! I'm guessing it'll be at B3R?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-30-2018, 04:12 AM   #59
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
i do hope so!
