Closed Thread
Old 03-06-2015, 11:09 AM   #1
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
Headlights...no power
Any ideas as to why I am not getting any voltage (low or high beam) to the headlight plugs? Fuses and fusible link are good, I have 12v coming off of the switch, headlight motors work properly....just not getting any juice to either headlight plug.
Any thoughts?
JTB
87 TII
jtbshaw is offline
Old 03-06-2015, 11:27 AM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
FC? If so check your headlight relays.
GySgtFrank is offline
Old 03-06-2015, 11:28 AM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
Have you confirmed both relays still work? Power passes through both the headlight relay and dimmer relay regardless if the highs are on or not. A quick check would be if the high beam indicator illuminates when they're switched on.
EDIT:
This.
infernosg is offline
Old 03-06-2015, 08:46 PM   #4
jtbshaw
jtbshaw's Avatar
Thanks guys. I will check them tomorrow. Thought I was going to tonight but opted to take my wife out for dinner.
jtbshaw is offline
Old 03-10-2015, 12:05 AM   #5
jtbshaw
jtbshaw's Avatar
The issue was the headlight relay...or lack thereof one. Wired in a new relay and now HIDs with projector lenses work great.
Thanks for the help.
JTB
jtbshaw is offline
Closed Thread
