Old 06-22-2008, 07:08 PM   #1
JL1RX7
Oil sender replacement
Ok I have to replace the oil sender in my 91 vert. I have never done this repair so I was looking for some tips and what and what not to do. Thanks!!!
Old 08-11-2008, 09:26 AM   #2
JL1RX7
Ok I have replaced the sending unit. But my pressure gauge is still pegged out to the top. This is even when the car is off. Anybody have some ideas of what else to check and or replace.
Old 08-11-2008, 10:14 AM   #3
the gauge itself probably broke when when the sender went haywire and its stuck there (probably for good)... with the wire to the sender disconnected does the needle drop??
Old 08-11-2008, 03:52 PM   #4
JL1RX7
nope not at all, stays pegged all the time. Even when you disconnect the battery its still pegged out. I haven't pulled the cluster out yet. I havent yanked one on a vert with a airbag yet. So thats my last resort.
Old 08-11-2008, 04:15 PM   #5
TehMonkay
Bad gauge or a short in the wiring
Is the condensor still attached to the slave cylinder?
Old 08-11-2008, 04:41 PM   #6
JL1RX7
yea i was going to get a new one of those next to see if that did the trick beofre hunting for the gauge.
Old 08-11-2008, 07:48 PM   #7
misterstyx69
.drives like MrMagoo!
misterstyx69's Avatar
misterstyx69 is on a distinguished road
get the Capacitor thingie(wire that attches to the slave) First...if that Works then you got off lucky.If not you may have to get another gauge AND an ECU.( I may be wrong,but I read about the Gauge taking out something on the ECU also(S5).I hate to say it.But Look into the other BIG forum,as it would have more Info Achived..)best of luck to ya,.STYX.
misterstyx69 is offline   Reply With Quote
Old 08-11-2008, 10:02 PM   #8
JL1RX7
yea i remember something about that and will search. I hope it did not. But the car runs fine, no codes etc. So I am hoping that it didn't fry something on the ECU. But the condenser/cap thing is next on my list.
Old 08-14-2008, 05:57 AM   #9
Actually, it's a broken connection...
High resistance means high on the gauge.
"Short" would imply resistance goes to zero, and that would cause the gauge to sit at "0" all the time.
Sounds like a broken wire somewhere.
Old 08-14-2008, 12:05 PM   #10
Boostmaniac
RETed FTMFW!
Old 08-14-2008, 08:00 PM   #11
JL1RX7
ted the question then would be the break! LOL having to do wiring and the like on jet doesn't mean i really want to do it on the car. But thanks for the info and I will hunt for it this weekend.
Old 08-14-2008, 10:01 PM   #12
Easy test...
Disconnect the wire off the sender...
Does this change the way the gauge reacts?
I bet it doesn't.
On the good side, it's just a single wire going straight to the gauge cluster.
If you want to rewire it, just run a single wire straight to the back of the instrument cluster.
Old 08-15-2008, 12:55 PM   #13
JL1RX7
Yep your right it doesn't do anything. I have to work all weekend. Got to love the navy, so next weekend I will try to run a new wire and connect things back up. Ted thanks!!!
