Rep Power: 14 ![]() |
Looking for PFC base map for ID 1000/2000
Just want to see what happens when I hook a PFC up to my car as a lot of people have suggested.
I'm looking for a base map supporting ID1000 pri and 2000 sec. It has AEM 3.5 bar map sensor. Not looking to boost, just to get it driving. ATM it won't rev past 2k rpm. thanks for the help guys!
#2 | ||
Rep Power: 17 ![]() |
Don Mega
you need to stop listening to random shitcunts.
define the problem and find its cause: Is the crank signal dropping out dur FFE shit set up? scope this If ok is the fueling correct for your ported motor? v's the stock calibration? This is not that hard. You will just waste time with another ECU, and a pfc does not run 1000cc inj well anyway. I do have a map I can send you but it will have mollested primary lag time so itca work @idle due to the pfc min injector limit restrictions.
The only problem i'm having it that it won't rev past 2k rpm. Both rotors are firing and seems to be working fine.. until 2k.
For the amount of effort it takes to hook up a pfc just to see what happens, i don't think its a waste of time. At idle the AFR is right around 11 +/- a little bit. Looking at the tune, that is right where the target AFR is in those cells so i really don't know what to make of everything.
#5 | |
Don Mega
It sounds like your trigger signal is dropping out as the thresholds are optimized for the stock set up, hard to diagnose from here. I will do up a file on the PFC for 3.5 bar sensor and ID1000 primary so you can test it, will send through tonight my time. I have a fully done and verified map for 550cc and 2200cc set up (which works perfectly on PFC platform), but to save you changing injectors I'll just molest some figures so you can run a test to validate your theory.
#6 | |
And what do you mean the triggers are optimized for stock setup.. Like stock ports or do you mean the FFE bracket thing? Cause the crank sensors are exactly the same location as factory it's just a dress uppy thing.
And yes I completely understand this especially given that you are strictly helping based off of information I'm relaying to you over the internet. I'm sure it would be a completely different story if you could just take a look in person for an hour or two so yes I definitely really appreciate your help
Don Mega
http://fullfunctioneng.com/product/trigger-kit-fd/ POST a pic of what you run? cause I have no idea why or what you have of you saying its still using the stock 12+1 Ne and G sensor set up with just are you using a 36-2 wheel set up like above?
If its totally stock if you have changed the GAP to the stock timing wheel this will change the voltage the ECU sees, and the trigger thresholds could be too high and thus your signals could be dropping out and hence not going over 2k rpm if all else checks out ok.
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 06-01-2014 at 11:25 PM. |
#9 |
Ah no, not the whole fancy trigger setup just this one bracket:
http://fullfunctioneng.com/product/oem-trigger-bracket/ I'm quite sure I checked the gap as well. FSM says between 1 and 2 mm or something like that and it's right there. Wouldn't hurt to check again though next weekend.
#10 | |||||||
Rep Power: 10 ![]() |
What ECU are you running?
Fucking that..... Quote:
Something else I saw on a PFC equipped shitbox was a single pin, the Ne signal, on the ecu got twisted. So when the connector was inserted the female socket on the connector got bent and really weak. Scoped it from the backside of the connector and everything looked fine so I kept on troubleshooting the bitch.... took a while to figure that one out and it was actually Dave that found it. Car would run fine until about 4k on the dyno then it would just start to skip and miss and not go past that point. So while the sensors were reporting correctly, the connection to the ECU was fragged and thus the ecu not seeing what it needed to... Quote:
What ignition system are you running, dwell time, what plugs, have you pulled the plugs? Quote:
#11 | |
The video you saw was really dumpy and not even running on 2 rotors. Did some fixing up and now at least both rotors are firing. This is a better vid: Still will be iphone quality though lol I'll check the wheel to make sure but I can't see there bein an issue there. It was pulled working fine and sat flat on a shelf for a year an a half. To check it what do I do just lay it on a flat surface or what? I have no knowledge whatsoever of tuning. I just see the crosshairs on the PC interface for the ecu in a certain target AFR cell an cross reference that with my wideband.. They are right around the same? At that point I assume it's all okay but I guess that isn't really a good assumption. Ignition is just the HKS unit and newer FD coils. Plugs are just the bur9eqp for now until the engine is broken in I've pulled them a few times - what specifically did you want to know? To check the crank signal pins are intact I should just pull them out? Now that I think about it one thin I should have done is hook the ecu up to a computer just to see if it's actually cutting fuel or ignition. Kind of hard to tell what's going on when the only thing you know is that it doesn't run
#12 | |||||||
Than it should be ok ESPECIALLY if it still has the same cal file on it.
What's your base FPSI? Quote:
Doesn't tell much without it being revv'ed to where it's fucking up.Quote:
Better would be to get an o-scope on the pins at the ECU and make sure it's getting a clean signal. FD harnesses aren't known for their robustness and something could've broken when the removed/installed. Or the sensors themselves are FUBAR. Quote:
Well... what are the AFR's when it's stuttering @ 2k? Quote:
![]() Quote:
Truff....
#13 | |
I'll get another video revving it on Friday so you can see. That is if the power fc doesn't magically make it work I know you say 11 is too fat - I believe you, don't worry, but that is the target AFR according to the map so I don't know what to tell you there I'm not sure the *exact* AFR when it starts cutting out but basically it revs normal, hits 2k, and you can hear there is absolutely no firing, the momentum the engine has caries the rpm up to about 2500 but you can hear it audibly cut out at about 2k, like there is nothing going on past there. So the AFR past 2k basically maxes out my meter at like 19+ cause it's just pumping a bunch I air through the engine at that point. I'll upgrade ignition later cut a guy a break Whenever I pulled them it was running on 1 rotor, so I'd sometimes have to pull them to deflood so .. Quite wet. Since it's been firing on 2 rotors I haven't really pulled them. All I an tell you is that I have idled the car for right around 15 seconds, killed it, and cranked it right back over and it starts no problem. Does the lack of flooding tell you anything you might want to know? Like I know you're suggesting that there's too much fuel but is that something that could cause the 2k thing or is that another issue in itself? I think I need to just see if the ecu is cutting fuel or spark as a first step I will check all that, I do remember testing the sensors as per FSM and they were right in spec. BTW, I'm not able to do anything on the car during the week so that's why I can't just give you straight up answers on a lot of this. Gotta wait till Friday
#14 |
What ecu is it and what is this target Afr table?
Longer reply when not on phone
#15 | |||||
Read whole post before proceeding nest time with the car...
As Peter said, you've got to troubleshoot it first before proceeding. It could be a variety of things ranging from some shitty trigger signals to poor tuning, horribly setup ECU parameters etc etc etc..... If it's Peters old link ecu and still has the same cal file on it, if he was running the same ID1000/2000 setup than the cal file likely isn't to blame. If it's been changed then all bets are off. And what I would do is first scope it and make sure it's getting a clean trigger signal. I don't know Links well enough to know if they've got a counter like the older helltechs but if it does, it would be a perfect 12:1 ratio. If it isn't, than it's getting some funky trigger signals. You may need to.... you may want to trim the pressure back until it's idling in the high 12's and then try revving it.... although I would change the plugs first to brandy new ones. Quote:
PFC's generally make things run worse ![]() Quote:
![]() Quote:
After that it could just be the plugs are shit and there's too much fuel and it's cutting out.... could be as simple as that. I had an issue a month ago where my car wouldn't idle... it would start just fine but as it would idle down it would keep dropping and just die. I thought maybe the TPS was out of whack, a whole bunch of things and it turned out to be nothing more than shitty plugs... same bur9eq's but a year old... Gotcha
