| Interior, Stereo, Body kits, etc... Place where you could talk about car care, body kits, painting your car, Carbon Fiber, Thumping Stereo, etc.. |
IT'S ALIVE!
Rep Power: 17 ![]() |
Fused Starter?
I've noticed a lot of people relocating their batteries to the cabin use a ~150A breaker right after the battery then run a large gauge wire to the stock pickup point in the engine bay. This obviously results in the starter being restricted to ~150A+. The stock setup doesn't have the starter fused but I'm not aware of people with relocated batteries tripping breakers left and right. Do our starters really draw less than 150A? I know some V8 starters can pull 200A+.
2 - 3 tries on an FC turbo starter will trip a 100A no problem.
Each try averaging about 5 - 10 seconds. I would recommend a minimum of 150A on the circuit breakers, unless you like tripping and resetting them all the time. It could be used as a security feature? ![]() A good, working starter should fire the engine on the first try. I run a pair of old-school 200A circuit breakers and have had zero problems of them tripping with the starter. You can find 150A units pretty easily, but I can't find higher rated ones like these anymore these days. -Ted |
