| Introduce yourself!! Tell me something about you and your history with rotary.. |
Mazdarx7 gs 12a
Greetings all. I got me a rotary car for 400 cash recently and have been looking to car show an maybe track race with it. My current problem is it needs an engine rebuild. No clue how to do it an no clue where to find parts with out paying an arm and a leg. Currently I am parking it, the front seal went an it wont hold oil.
Brokeback Power!
Welcome to the forum! on occasion you can find people selling 12A's for super cheap, depending on how much you are willing to spend.
Depending on your budget, you might could also pick up a "parts" car with a good motor in it, and canabalize one of them? |
Yeah a partscar would befun but i have no way to transport it. Igot a 12a without a carb for 200 dollars out of a truck that shredded a driveline.
It is amazing the abuse the rotary can take. *till running the old motor an doing some light street racing. I have a question though how much torqe on the two an an eigth or otherwise known 54 mm flywheel bolt ? I keep seeing 350 foot pounds
Location?
I have an 84 rx 7 gs for sale for 800 today! same motor 12a 1.1 4 barrel 59,000 miles original but mine needs a new shell my interior is excellent all glass and motor clutch is a year old radiator year old ac was installed in car 3 yrs ago have remanufacter master cylinder ordered by accident new slave and waiting on clutch master in mail. where r u located? tires have about 90% tread on them original straight rims and so much more....excellent car i drive it everyday but as i said shell needs that much work it is better off with a new one
I'm in Idaho. Mine has 165k miles 2nd engine. Gonna be dropping the third motor in soon. Been way to busy though. Carb is barely functioning an the oil leak is getting worse. Rugged lil car though, was think worst comes to worst i found a few nissan engines that will fit. I know bad ju ju but i know nissan a tad better an more off the line power.
Rep Power: 21 ![]() |
where are you? boise? used to live in boise / mtn. home.
is the oil leak from the cracked iron? (ie unstoppable from side of engine?) there is an idaho rotary group, i think on facebook and they have a website. guy ahold of either Monte or RXTascy (spelling?) on Rx7club / occasionally here. Both in idaho and very helpful
Sorry been away again im in twin falls. The leak is the front keg oil rinf between the front rotar and the front plate that holds the water pump. the new 200 dollar engine is almost ready to drop in just got a new block heater an carburator. I'm getting a 4 port injection system and a computer that will run off the distributor, fully tuneable to squeeze every thing i can from it. Also will be building the second keg i have port an polished with new guts excluding the accentric an rotors. i inverted the camber for drifting. loves it on ice.
#9 |
So here is an up date. Rx wont start. i pulled the plugs and had a shit ton of gas run out. i'm thinking carb ?
