Old 10-12-2013, 10:14 PM   #16
omega
The new Sheriff in town..
omega's Avatar
omega is on a distinguished road
Check the ball and spring to see if there is a broken spring. Its the ones that are held in by a sleeved bolt. That helps with the return..
omega is offline   Reply With Quote
Old 10-14-2013, 05:20 PM   #17
IIRC, the lower ball on an s5 shifter is small and uses a nylon bushing in the extension arm cup.
http://www.mazdatrix.com/g4.htm
S4 shifters have a larger lower ball and uses no bushing. Is there play where the lower ball and cup interact?
It could be that when moving over to 1-2, there isn't much force on the spring as there is play between the lower ball and the cup.
When you move over to 5-6, the tension is on the coil spring, and you still get rebound..
Old 10-15-2013, 06:08 AM   #18
jahjahsqc
jahjahsqc is on a distinguished road
Thats a good thought. I never thought about that. I wish I had an original S4 shifter to compare the two.
I've got everything back together right now with the S5 shifter, and I hit the shifter bushings with a little silicone spray and with the slightest amount of effort it springs back back from the 1/2 gate. Good enough for me for right now.
jahjahsqc is offline   Reply With Quote
Old 10-23-2013, 10:44 AM   #19
omega
omega's Avatar
So did you check the spring tension on the side spring and ball ?
Old 10-23-2013, 10:57 AM   #20
jahjahsqc
You mean that spring brings the shifter back from the 5/R gate? Yes it works fine. I don't have a problem with the RH gate, just the LH gate.
Old 10-24-2013, 07:18 PM   #21
omega
omega's Avatar
Also did you put gear fluid in ? Just asking because it was not mentioned. If not, only fill it halfway .
