Old 08-21-2013, 01:03 AM   #1
Remove airbag=no horn
I removed my airbag recently and was trying to figure out what I removed that would make the horn not work. All I removed was the passenger side airbag itself, and the impact sensor and harness from the engine bay. With some guidance from a couple fellow FD owners, I simply cut the connector off my airbag harness, spliced the wires together, and plugged it back in. Works like a charm.
Just wanted to put this out there just in case someone else does the same thing and has the same problem.
