Old 03-10-2013, 03:46 PM   #16
Rx7Spaz
Spirit II in Progress
Rx7Spaz's Avatar
Rx7Spaz is on a distinguished road
Late 2010
More pics
~1991 Rx7 - Spirit II - Finishing a Turbo swap for DGRR 2013
~1993 Rx7 Touring - Sharyn - Currently awaiting rebuild
~1987 Rx7 My 1st Rotary - Faygo - R.I.P.
Driving Rotary since 2003
Rx7Spaz is offline   Reply With Quote
Old 03-10-2013, 03:55 PM   #17
Rx7Spaz
Rx7Spaz's Avatar
Late 2010
New wheels and tires and Christmas in Decatur, IL
Old 03-10-2013, 04:24 PM   #18
Rx7Spaz
Rx7Spaz's Avatar
Cool Carbon locked engine Jan. 2011
Everything was rotating fine until I shut it off in January 2011.. Once I took the engine apart I noticed one of the apex seals was jammed in the rotor and left some scarring on the housing. Goodtimes
Old 03-10-2013, 07:35 PM   #19
infernosg
IT'S ALIVE!
infernosg's Avatar
Something's wrong with your headlights
Old 03-11-2013, 08:19 AM   #20
diabolical1
I have radioactive semen
a bit thin on details, but i see you're having fun as you build and that's a good thing.
Old 03-11-2013, 08:53 AM   #21
Spaz!
Looking good man. Can't wait to see it next month. What wheels are those?
Old 03-12-2013, 12:27 AM   #22
Welcome! It's looking good!
Old 08-08-2013, 01:07 PM   #23
Rx7Spaz
Rx7Spaz's Avatar
It's been awhile since I last posted on here. In the last 5 months I managed to complete the turbo swap in my 91 Fc, installed the fmic and all the piping. I got it to the point where it cranks over but does not start. I've been doing tons of reading on all of the rotary sites and still having no luck... I'm constantly tinkering with my 7 and I've replaced just about everything. New plugs & wires, injectors, ecu, all turbo sensors. Checked everything over and over again... I keep running into the same problem where the injectors just won't fire. The pump is working fine, fuel is filling the lines. I've got air pressure and spark, I can get it to run while spraying throttle/carb cleaner in the intake. But it will not start or run on its own. I've checked all of the fuses and grounds. Frustration is at full capacity whenever it comes to this project. I'm tired of spending more money on it and having no results, I'd like to start working on my 93 Fd again. Any help or input is greatly appreciated since I do all the work myself. Once again, thanks for stopping by and I'll try to upload more pics
Old 08-08-2013, 01:08 PM   #24
RedR1
Brokeback Power!
RedR1's Avatar
RedR1 will become famous soon enough
when you have questions on the FD, feel free to post! I don't have much experience with FC, but FD i can help if it's not super hard issues with wiring
RedR1 is offline   Reply With Quote
Old 08-08-2013, 02:26 PM   #25
Rx7Spaz
Rx7Spaz's Avatar
I need to start a build thread for my Fd which has been a project for the last 8 years. Sadly it has spent most of the time broken. It's in need of a newer engine. First car I've ever installed an engine in, the vacuum lines were quite the experience haha. I grew up around my father's automotive shop so I'm a bit of a natural at the mechanical stuff. Although, some of the electrical stuff stumps me which is probably the problem with my Fc.
Old 08-08-2013, 05:40 PM   #26
Rx7Spaz
Rx7Spaz's Avatar
Shuk rims Front 17x8 with 38 offset Tires Kuhmo Ecsta MX 225/ 45/R17 Rear 17x8.5 with 39 0ffset Tires Kuhmo Ecsta MX 255/40/ R17
Old 10-17-2013, 04:56 PM   #27
chrisflaco_fc
chrisflaco_fc's Avatar
chrisflaco_fc is on a distinguished road
I'd check the map on your ecu.
chrisflaco_fc is offline   Reply With Quote
Old 10-17-2013, 05:16 PM   #28
Wut?
