Old 01-16-2013, 02:10 PM   #121
Topgear
Topgear is on a distinguished road
Ok everything on the tank is finished
Level sensor fitted this will switch on a small red light on the dash once the level is below halfway
Tank holds 3.5ltrs
Here are the photos
95 FD3S Type RB Project BorgBoost 550BHP
93 FD3S Project 26B
1200+bhp rolling road dyno
+44161 4948343
www.tgstuning.co.uk
https://instagram.com/craigtgs/
Car looks jizzfactor3000 good!
Topgear is offline   Reply With Quote
Old 01-16-2013, 03:37 PM   #122
Erdin
Erdin's Avatar
Erdin is on a distinguished road
Thats a mighty fine system you got there
Erdin is offline   Reply With Quote
Old 01-16-2013, 03:43 PM   #123
Topgear
Why thank you kind sir MWI systems you know
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 01-16-2013, 03:45 PM   #124
RICE RACING
Don Mega
RICE RACING's Avatar
For your 6mm nylon tubing here is a trick to make it more PRO (lol)
Put a piece of electrical wire up it (to stop tube from collapsing) and heat it up gently with a heat gun and BEND it to suit your application it then stays in position perfectly and looks sick as fuck
I have mine routed in all kinds of places, and in hot environments I sleeve it as well. Little tricks you learn over 20 years
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-16-2013, 03:46 PM   #125
Erdin
Erdin's Avatar
Would that trick still work for 8mm hose?
Old 01-16-2013, 04:32 PM   #126
Topgear
I will try it out tomorrow Peter and report back thanks for that
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 01-19-2013, 03:50 AM   #127
Topgear
It took me a few try's as I kept getting the cable stuck in the tube, but then I found if I lubed the wire and moved it while heating I could bend away
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 01-19-2013, 03:54 AM   #128
Topgear
Ps I just opened a new forum/blog on my site check it out guys
http://www.topgearstockport.co.uk/forum/index.html
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 01-21-2013, 02:16 PM   #129
Topgear
Ok last one I promise of the tank
Photo shows water feed pipe from the sump with nice long 90 bends
Water level sensor loom all sorted with waterproof fittings
Cheers
Craig
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 02-04-2013, 01:39 PM   #130
Topgear
Little update
Have put my order in for a nice large intercooler but she is going to take around 30-40 days after that the car should be done
Tonight I got to work making up a shot blasting cabinet
Then I stuck the red upper and lower cosmo manifolds in there
Then a quick clean up of the logo
This has to be the best tool I've made/bought no more sending stuff out to be cleaned.
I'm going to keep the manifold this way now as it matches my turbo
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 02-04-2013, 02:18 PM   #131
RXtacy
RXtacy's Avatar
Looks good
You might want to clear coat the manifolds, as they can oxidize over time.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-05-2013, 01:30 PM   #132
Topgear
Few more shots of a quick mock up of the intake system, I will be removing this lot again to apply the heat treatment sheets to the lim and under the upper
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 03-10-2013, 02:36 PM   #133
Topgear
Quick update nothing big
I have the intercooler sized up and ready to be made now so soon as that's ready I should be back on the road
I am still on the look out for a GM 3bar map sensor
Anyways after cleaning up the intake I had to redo all the heat shielding so that's what I've been upto this afternoon
Enjoy
This stuff is great developed for Porsche I'm using it here to stop as much heat entering the loom and fuel lines
Then onto using the speed shield on the water lines and fuel lines
Mock up of the new intercooler
Vulcan heat shield beanie for the turbo I will also be boxing in the manifold with this I'm hoping with a duct to the front or underside of the front flat floor
That's me
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
Old 03-25-2013, 06:27 PM   #134
vst8
vst8 is on a distinguished road
very nice build. i want your vmount setup.
vst8 is offline   Reply With Quote
Old 03-26-2013, 10:23 AM   #135
Topgear
I will be offering the new v-mount kit on my website in a few months once I have all the testing done keep your eyes peeled
93 FD3S Project 26B
+44161 4948343
www.tgstuning.co.uk
fd3s, fduk, mwi, rx7, topgear stockport
