|  08-26-2012, 08:27 PM | #166 | |
| Founder/Administrator/Internet Pitbull :) Join Date: Jan 2008
				Rep Power: 10   | Quote:
 Aug. 26th, 2012 Let's see what I've been up to... Friday, I went over to my long time friend, Bryan at www.BNRSupercars.com to use his sand blast to clean up some suspension parts.     And yesterday, I was pressing on some Powerflex Bushings. I heard great stuff about them and once the old stuff were pushed out, install was a simple hand press in. I was amazed how easy it was since I've installed a set of Delrins in the past. Quality of Powerflex bushing were awesome!!   But I did break something... Lack of sleep and hurry to get the job done, I did this..  Luckily I had a spare  I also decided to refinish my Alcon calipers for this..  Did a pretty good job on one, but other one, I kind of messed up and have to re do it..  Anyhow, Tomorrow, I'm re blasting the one I messed up and re doing it.
				__________________ DGRR 2013 - Year of 13B www.DealsGapRotaryRally.com http://www.facebook.com/Herblenny | |
|  09-02-2012, 09:38 PM | #167 |
				Rep Power: 10   |
			Sept. 2nd, 2012 Well, I been busy trying to fabricate some stuff and re-doing my caliper that I messed up. I had a chance to re-sand blast and re paint them.  now looks perfect   Also, an announcement of new LIM for 20B!! I was lucky enough to hear about this LIM 6 months ago and now I can show it off to you guys.  This one isn't my photo.  More information about the LIM and more pics later...
|  09-05-2012, 02:23 PM | #168 |
| Rotary Fanatic Join Date: Mar 2008 Location: Phoenix, AZ
				Rep Power: 18  |
			OK Phil, so SEMA is less than 2 months from now.  Are you still planning to make it??  Seems to me like there is still a TON of work and reassembly to be completed!    |
|  09-05-2012, 08:58 PM | #169 | |
 Sept. 5th, 2012 Worked on few this over the past few days..  Cluster surround, fiberglassed and process of smoothing out. making my own MS R-Spec signal lights   Studded everything and shorten bolts so I could put FD chrome nuts and bolts for the LIM.  This was from about 3-5 FD engines  And starting to test fit everything and such..
|  09-07-2012, 09:49 PM | #170 |
| 600rwhp club member. Join Date: Mar 2008
				Rep Power: 18  |
			Some really cool parts in this build.  That turbo setup looks mean!   We just need to mini tub it and fit some skinnys and fatties on it...   |
|  09-09-2012, 10:08 AM | #171 |
| Rotary Fanatic Join Date: Mar 2008 Location: chatsworth, california
				Rep Power: 18  |
			a work of art! very nice. cant wait to see it completed!
				__________________    rotaryshack.com |
|  09-10-2012, 09:53 AM | #172 | |
  One day Mike,... One day.. Thanks! Hopefully soon...
|  09-10-2012, 09:55 AM | #173 |
				Rep Power: 10   |
			Sept. 10th, 2012 Well, some update.. but before that, some of the goodies that are going in in this car.. Aluminum rack..    Carbon Shaft.  FEED trunk thingy in carbon
|  09-12-2012, 03:42 PM | #174 |
| Do Work!! Join Date: Apr 2009
				Rep Power: 0  |
			Does your "FEED trunk thingy" sit in place of the spare tire?
				__________________ Rotary Son!! |
|  09-12-2012, 07:59 PM | #175 | ||
| Half bubble off plumb Join Date: Jan 2010 Location: middle of Alberta
				Rep Power: 16  |
			Yes it sits in the spare tire well...  I remember when you first got that Phil... I was so green with envy... Lol J.
				__________________ Quote:
 "The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis | ||
|  09-13-2012, 05:26 PM | #176 | |
|  09-13-2012, 05:29 PM | #177 |
				Rep Power: 10   |
			Sept 13th, 2012 I finally took some time to work on the rear diffs of the FD RX-7s. Here are some pics of the diffs. Stock vs Kaaz  After cleaning the case, sanding it down, and re painting it with epoxy paint,.. I put the new covers on. Stock vs. Greddy higher fluid capacity cover.
|  09-16-2012, 10:04 PM | #178 |
				Rep Power: 10   |
			Sept 16th, 2012 - Little bit more update...  Took some time getting the transmission painted and such.. Some color scheme.   and becoming a master of taping   Also, plugged the oil metering hole   and another angle of the painted diff..
|  09-17-2012, 02:33 PM | #179 |
				Rep Power: 18  |
			Looking good Phil.  How long before the body shop completes the paint?
|  09-19-2012, 07:52 PM | #180 |
				Rep Power: 10   |
			Thanks! Well, hopefully within 2 weeks.. Til then I have interior stuff to finish and then assembly time.
