Old 07-26-2012, 09:38 PM   #1
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Rx8 prospect
Hello all. So I found an 2004 8 that I'm thinking of trying to pick up. I remember a while back reading that they had a few issues here and there (ie coil packs going out). Are there any other common issues with that particular model year that I should be aware of and address ASAP if I was to get ahold of it? Thanks for the advice in advance.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 07-26-2012, 10:54 PM   #2
Dannobre
Dannobre is on a distinguished road
Motor has an 8yr extended warranty that likely is over...read up on the engine quirks and make sure you get it cheap enough if the motor isn't in good shape. Personally I would pay for a compression test to give you some piece of mind unless it is a DIY project
Dannobre is offline   Reply With Quote
Old 07-26-2012, 11:08 PM   #3
lilring
Rotary Man
lilring's Avatar
lilring is on a distinguished road
for a coil upgrade, look at raceroots.com or BlackHaloRacing.com once you buy them your set for like pretty much.
2005 Mazda RX-8 Velocity Red Mica - Daily Driver
2004 Mazda RX-8 Titanium Gray Metallic - RIP
1997 Mitshibishi Eclipse GST Black -Sold- RIP
lilring is offline   Reply With Quote
Old 07-26-2012, 11:26 PM   #4
The coils are most common failure, but the 04 starter is weak and the sun visors arent great either.... upgrade both to 06 or newer and you will be set...
Old 07-27-2012, 06:59 AM   #5
lilring
Rotary Man
lilring's Avatar
If you buy a new Starter, it can actually be off a 2009 or newer. the S2 starters are even better and its a direct fit
Old 07-27-2012, 01:54 PM   #6
project86
project86's Avatar
Thanks for the advice. If its of any help it's got pretty low miles... 76 k
'90 GTUs
'10 Toyota Prius
Old 07-27-2012, 02:35 PM   #7
JL1RX7
Make sure its got all the TSB's and ECM flashes up to date. Highly doubtful the 8 year/100k engine warranty is still left. But its worth a look and a compression check.
Old 07-28-2012, 10:05 PM   #8
project86
project86's Avatar
Well they sold it before I could get there for the test drive... Sad day. I looked around in the web to see l if there were more in the area but there don't seem to be many around Eglin... Oh well...
'90 GTUs
'10 Toyota Prius
