#241 |
Rep Power: 15 ![]() |
Thanks guys! I will try to keep the pace now when I feel the flow.
Some days, I just wanna blow the whole shit up in the air
#242 |
Today I did a mockup to see that the coilover-lenght could ba about right, and that the angles looks good in the car.
I also got som used rear tires, also to mockup and make sure the fit later. 225/45-17" Front 255/40-17" Rear ![]() ![]() ![]()
#243 | |
Professional Stick Poker
#244 |
I see that you say "four rotor" build. how about some images of the motor build?
#245 |
Rep Power: 20 ![]() |
Look at the whole thread.
#246 |
You got to have a car to put the engine in. There's alot of time there!
#247 |
FC3S
Looking gorgeous as always buddy, do you have the shaft back yet?
#248 |
I have Ultra power in me.
So how much of this car will you still be able to call a Volvo?
#249 |
FC3S
I'm going to assume the badge. Lol
#250 |
On the outside the car will look original, but rather low, about 150mm lower than stock
![]() But Volvo have thought about this idea a looong time. This Badge the had on the P1800-model. I think they wanted to say something ![]()
#251 |
I recieved a rod yesterday, Delrin, for bushings. My wife is happy with me as I am
Coming to these using a stainless steel sleeve model 16x2mm.![]() This is what it would look like, as common. ![]() Then today I got to work hard because I do not have access to laser-cutter. Began to mill as deep as I dared, without them to come off, and the plate begins to vibrate and break the cutter. Then there has been much handwork! Good for me, to practice a bit. Continued on these! ![]()
#252 |
Came up with an new idea about the Camber-adjustment. Simple to adjust with only one tool, and no need for deassembly anything around it.
![]() 4pc Ø30mm steel. Did not have the possibility to use the CNC-lathe tonight, so it has been some therapy in the manual lathe. M20x1.5 thread for streanght and good adjustments. ![]() ![]()
#253 |
Don Mega
You are a bad boy holding black steel in the three jaw!!!!
#254 |
Why not? What else could I've done?
#255 | |
