Old 06-12-2009, 09:54 PM   #31
Originally Posted by Signal 2 View Post
All interesting reading...thanks to VEX and all contributors. My head's spinning since I'm just a dumb goverment employee.
My question is that in the F I models, how well or poor the oil burns is only half the equation. How it performs in the high heat and extreme rpm turbo enviroment is the other. For that, it seems synthetic is superior. Is there something to look for in the analysis/content charts that would help a chemistry challenged lay-person balance those needs?
One would think. The trouble with our cars however is that even naturally aspirated we need rather good oil. There should be no difference in the oil you use from a turbo car from an NA car.
You're still looking for the base materials to be extremely low. IE: Calcium. The lower the ppm (parts per million) the better, while additives like zinc, and some detergents will prove beneficial so long as there's not too much. Especially if the car is turbo, which would lead to a fair amount of foaming. I'm trying to find some VR1 oil that was mentioned, but so far my searching has returned nill.
Old 06-15-2009, 06:35 AM   #32
Barry Bordes
Barry Bordes's Avatar
Found VR1 at Autozone and O'Rielly's in 20w50 and straight 50w. Wanted 10w30. It is not a synthetic oil.
Barry
Barry Bordes is offline   Reply With Quote
Old 06-15-2009, 07:15 PM   #33
Signal 2
Viable Fossil
Signal 2's Avatar
My local ADVANCE AUTO only carries it in 20w-50 as well.
......There should be no difference in the oil you use from a turbo car from an NA car.....
I don't understand. Aren't synthetic's generally more resistant to shear and coking? And isn't this a concern with the extreme rpm and heat of turbos?
Jim
VR R1 FD
Old 06-15-2009, 08:07 PM   #34
The benefit of synthetic over conventional is the base they use. On the previous pages compare what is known as synthetic to good grades of conventional such as VR1. You could have a "good" synthetic with worse qualities for our engines than a top rated conventional. Drawing generalities across the board will cause trouble for people.
If you however compare VR1 to an oil like royal purple would you see a difference, I don't know. I don't know the UOA or the VOA's of the two.
Old 06-25-2009, 08:39 AM   #35
Advance carries 20w-50 (but they never seem to be in stock) and 50... I ended up doing royal purple 10w-30 (though I would really like to run 20w-50 when it comes around) for the time being.
I've also noticed a price difference between the two. About a full dollar or more just at advance....
Old 06-14-2012, 01:44 AM   #36
ZR1 Synthetic stats: http://www.valvoline.com/pdf/vr1_synthetic.pdf
ZR1 Conventional Stats: http://www.valvoline.com/pdf/vr1_racing.pdf
ZR1 Racing (non-street legal): http://www.valvoline.com/pdf/specialty_racing.pdf
Old 06-14-2012, 07:10 AM   #37
Jwteknix
Jwteknix's Avatar
Jwteknix is on a distinguished road
Whys one not street legal?
-88 SE -Wht on Blk, Goopy motor, HKS TO4r, Haltech PS 1000, FD UIM, a1000 pump & FPR,....(underconstruction)
-91 tII -Blk on blk -(SOLD)
Jwteknix is offline   Reply With Quote
Old 06-14-2012, 12:45 PM   #38
According to mazpower; it deals with the anti-wear package and how much ZDDP is in the oil. Too much and it will clog cats.
Old 06-15-2012, 12:59 AM   #39
Valvoline
Conventional: http://www.valvoline.com/pdf/premium_conventional.pdf
(sulphated ash:0.8)
Conventional - Next Gen: http://www.valvoline.com/pdf/nextgen_conventional.pdf
(sulphated ash: 0.8)
MaxLife: http://www.valvoline.com/pdf/maxlife.pdf
(sulphated ash: 0.93)
MaxLife Synthetic: http://www.valvoline.com/pdf/maxlife_full_synthetic.pdf
MaxLife NextGen: http://www.valvoline.com/pdf/nextgen_maxlife.pdf
Durablend Synthetic: http://www.valvoline.com/pdf/durablend.pdf
(sulphated ash: 0.99)
Synpower: http://www.valvoline.com/pdf/synpower.pdf
Mobile 1
Extended performance: http://www.mobil.com/USA-English/Lub...rformance.aspx
Advanced Fuel Economy: http://www.mobil.com/USA-English/Lub...l_Economy.aspx
Mobil 1 0w-40: http://www.mobil.com/USA-English/Lub...l_1_0W-40.aspx
(sulphated ash: 1.3)
Mobil 1 5w-20: http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx
(sulphated ash: .85)
Mobil 1 5w-30: http://www.mobil.com/USA-English/Lub...il1_5W-30.aspx
(sulphated ash: .8)
Mobile 1 10w-30: http://www.mobil.com/USA-English/Lub..._1_10W-30.aspx
(sulphated ash: .8)
Mobile 1 15w-50: http://www.mobil.com/USA-English/Lub...l1_15W-50.aspx
(sulphated ash: 1.21)
More to come.
Old 06-15-2012, 01:11 AM   #40
Royal Purple... can't find anything from their site.
HPS: http://www.bobistheoilguy.com/forums...49#Post2578549
Old 06-18-2012, 12:16 PM   #41
Are there any specific oils people would like more information on?
