Old 03-26-2012, 06:04 AM   #1
fc nut
member
fc nut is on a distinguished road
my 84 se start problems
I have an 84 gsl se,with a s4 n/a engine installed. there's no power going to the coils. The egine ran fine before i pulled the car out of the garage.here's a list of known good used parts I've changed out.
computer
distributor
coils
new plugs & wires
fuseable links
airflow meter
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 04-03-2012, 06:38 PM   #2
fc nut
member
ok,i put the original distributor back in and the tach was barely moving. the leading is sparking and yet it won't even attempt to start. it cranks,but won't start. what controls the trailing coil? i need help bad.
Old 04-03-2012, 07:35 PM   #3
2gslse
it looks like you are on the right track now the trailing ignition controls the tach and also the fuel pump circuit, have you checked to see if the pump primes? there is a plug on the pass side (a green plug I think) if you jump it the pump should run. Are you positive the good distributor was really good?
2006 VW TDI commuter
Old 04-04-2012, 04:40 AM   #4
fc nut
member
I wasn't sure about the distributor I got ,so I put the original back in. I'll check that plug you're talking about today when I get home from work. it is getting fuel and that's why I'm baffled as to what it could be.
Old 04-09-2012, 09:44 AM   #5
fc nut
member
could the s4 alternator I'm using have effected the se's electrical system to cause this issue?
Old 04-09-2012, 03:33 PM   #6
2gslse
No. I have used an S4 alternator on a first gen for years they are pretty much identical just a few amps more capacity.
It has to be something really simple wrong with the car, you have put so much time in it and had it running it is time to go over the basics the car is still basically a GSLSE the engine core doesn't really matter and the manifolds are just moving air the fuel and ignition system doesn't know any different. is everything grounded really well?
Old 04-09-2012, 04:18 PM   #7
fc nut
member
I actually added 3 extra ground wires to the engine. I grounded the trans to engine to the body, the upper intake manifold to the body and the front iron to the frame. is there another relay that could be bad?
Old 04-09-2012, 04:30 PM   #8
2gslse
I don't think there are any other relays. Have you ever had spark on the trailing side yet? I don't remember for sure but it may also control the injectors I wish my old SE was still here and running to verify.
Old 04-12-2012, 02:54 PM   #9
Oyvindjs
Oyvindjs is on a distinguished road
How do you know its sparking properly? Do you have a voltmeter at hand to check? Do you have the FSM? If so, check in the FSM, start at ground zero, battery, and meassure over each component, out to plugs.
Oyvindjs is offline   Reply With Quote
Old 04-15-2012, 08:57 PM   #10
fc nut
member
my problem is solved. when I temperarily fixed the harness,I just spliced the wires together. I know,not the right way. today I soldered all the wires that were chewed up. I also tapped into two of the ground wires for the ecu and ran an extra ground to the chassis. after I did that it fired right up. I'm assuming the ecu had bad grounds. that might be the culprit for other se owners as well.
thanks everyone.... for all the help in trying to find the issue.
