| Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096 |
Administrator
Rep Power: 10 ![]() |
Rotary-engine Compression Tester Systems www.rotarydiagnostics.com
I would like to thank Larry at Rotary Diagnostics Systems for his support of RCC! His contribution will go towards the continued promotion of this forum.
Check out his website www.RotaryDiagnostics.com and feel free to post questions for more information on his Rotary-engine Compression Tester Systems. Thank you! Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. Figure 1. Model ReCT-TRT, Two-rotor Compression Tester System. The Processing Unit includes an enclosure containing the analog-to-digital converter, DIN data sockets for 2 Acquisition Units, plus the power and data connections. Power and USB cables, as well as the programs CD are a part of the Processing Unit. The Processing Unit receives analog signals from the Acquisition Units during a compression test and converts them to a digital data stream for transmission to the computer for recording and later display and analysis. The Acquisition Units consist of precision pressure transducers with attached 30" cable and DIN connector, a spark plug hole adapter with swivel air plug, and a quick coupler fitting for easy connection of the components.
Kevin
The fan hit the shit!
Rep Power: 15 ![]() |
Group buy?........
Rep Power: 17 ![]() |
whats the price on that bad boy...?
http://www.rotarydiagnostics.com/pricing%20combined.htm .......found it
SARX + Boosted = Win
Anyone have an experience using this product?
I have had one for 4 years...works well....It is much more complex than the Mazda tester to use the first time..but after you have done it it is quite easy
It also gives you more data than the Mazda tester... |
Still Building my FD
$640 ... no thanks. And $225 for a software upgrade in sampling rate? Alrighty then Motec.
If the two rotor system was reasonably priced, I would have already purchased one.
Uh.... hi. |
#8 | |
Compression Tester Man
The other systems we offer are intended primarily for engine builders and rotary shops where a higher resolution sampling rate provides detailed analysis of the compression pulses and where the presentation format of the data to their customers may be critical. Of course, we sell those system to individuals as well. There, now I feel better. ![]() Larry Roberts Rotary Diagnostic Systems |
#9 |
I appreciate your very professional response to my post which was in poor taste. My apologies. I guess I'm just a cheapskate.
Uh.... hi. |
#10 |
#11 |
LOL...try and buy a Mazda one....even the $640 price looks like a steal then
#12 |
Well ya know, that could be why Mazda Australia opted to adopt our basic system for 60 of their dealerships. Ya think?
#13 | |
#14 |
Rep Power: 21 ![]() |
#15 |
Fourth this?
Uh.... hi. |
