Old 12-18-2011, 03:23 PM   #1
db86na
db86na's Avatar
db86na is on a distinguished road
black interior DIY
since its hard to find black interior and people want a arm and leg for little peices i decided to go the cheap way and dye my maroon interior plastics black and my carpet grey. this is the start ill keep updating the more i dye but so far it looks good
db86na is offline   Reply With Quote
Old 12-18-2011, 04:29 PM   #2
Raksj04
I have Ultra power in me.
Raksj04's Avatar
What product are you using?
Old 12-18-2011, 08:47 PM   #3
db86na
db86na's Avatar
its covering good on the plastics but the carpet is gonna need a few coats
Old 12-18-2011, 09:10 PM   #4
Pete_89T2
Pete_89T2's Avatar
Interesting thread. I wonder how well the dyed black hard plastic pieces would color match the existing Mazda black plastic bits? In your case this probably doesn't matter since you're re-coloring the entire interior, but if one was to start with a mostly black interior and could only find parts in other colors to complete it, it would be nice to only have to dye the parts that didn't match the original black.
Old 12-18-2011, 09:20 PM   #5
db86na
db86na's Avatar
i dont think it would matchbut but they did have a flat black dye u could spray a coat of gloss then a coat flat then it might come close
Old 12-19-2011, 03:05 PM   #6
db86na
db86na's Avatar
got some mor interior stipped
Old 12-19-2011, 03:13 PM   #7
Raksj04
Raksj04's Avatar
Yes rocking the two post steering wheel.
I would love to have a garage to give my FC this much TLC.
Old 12-19-2011, 05:08 PM   #8
db86na
db86na's Avatar
its just an apartment complex garage i got the car in one garage and a empty garage next to it to work in but i work here at the apartments so ima move the interior into a apartment and paint in there were its warm
Old 12-20-2011, 03:16 PM   #9
db86na
db86na's Avatar
so the plastic is dyeing good but the carpet is not guess ill try and find some carpet ,door panels ,head liner
Old 12-25-2011, 03:19 PM   #10
db86na
db86na's Avatar
its not origanal but better that maroon
Old 12-25-2011, 03:53 PM   #11
rotarycrazy
rotarycrazy's Avatar
rotarycrazy is on a distinguished road
not too bad I personally didnt have much luck with the paint I starts pealing off after a while. I have some interior dye that im waiting to use.
rotarycrazy is offline   Reply With Quote
Old 12-26-2011, 11:52 AM   #12
db86na
db86na's Avatar
it all depends on how much prep work you do and the temp of were your spraying
Old 12-26-2011, 12:04 PM   #13
My5ABaby
My5ABaby's Avatar
My paint is fine after 2 years. I cleaned with dish soap, lightly sanded for better adhesion, rinsed with rubbing alcohol, and then sprayed with Krylon plastic spray.
Community Service Manual
RotorWiki
Old 08-28-2012, 07:39 PM   #14
4port
4port is on a distinguished road
not to bad i might have to do that
4port is offline   Reply With Quote
Old 11-26-2012, 07:44 PM   #15
fc nut
member
fc nut is on a distinguished road
that's what I used on my old fc. I'll be using it on my sons gsl se interior.
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
