#46 | |
It terminates at that "ring" connector I outlined in purple at the long starter bolt. I dunno how you car is running, cause the later pics still show the main engine ground disconnected. ![]() You got additional grounds on the engine??? -Ted |
#47 |
Rep Power: 20 ![]() |
Hmm, that makes more sense now. I haven't had a reason to look down there for a few years.
#48 | |
Big Daddy
Hell hath no fury like a rotor blown. |
#49 |
Big Daddy
So those two loose wires, should they go on the front of the bolt that runs through the starter? I just took the starter off and I'm going to clean all the contacts and put it back on to see if that fixes my problems. Since that bolt is loose, I can put those two wires on pretty easily.
#50 |
Big Daddy
Just think how helpful it will be when someone is searching. This could be the end-all, be-all of starter threads.
#51 |
Big Daddy
Took the starter off, cleaned the contacts, bolted it back in, car fired right up.
That piece that was not attached was just a bracket holding a bunch of wires. The actual main engine ground was connected after all. I put the bracket on anyway. Car is good to go.
