Old 04-08-2008, 12:20 PM   #31
I feel I should chime in.
The starter is dead. Buy a new one.
This should be the end of the thread.
Old 04-08-2008, 12:35 PM   #32
My5ABaby
My5ABaby's Avatar
WHAT SCARES ME THE MOST IS THE FACT THAT THE MAIN ENGINE GROUND IS NOT CONNECTED!!!
Look BEHIND the black box in that pic - see the big ring terminal?
That's the main engine ground connection that is usually secured by the long starter bolt!
Originally Posted by classicauto View Post
Good idea.
Ted - didn't even see it. Its a tough point of view to distinguish things
I still don't see it. Or are we talking the sideways copper thing that you can barely see that may or may not be a figment of my imagination?
Old 04-08-2008, 01:16 PM   #33
I know what he's talking about. it is like a bracket that's connected to the wiring harness? there was a hole in the bracket, and the long starter bolt went through it... it's actually easier to get at that thing from above the car than below! I had to have a friend hold the bolt for me while I removed the nut underneath the car.
I now lol at those "I cant get my starter off, plz help" threads, because I was a victim as well, and had to figure it out on my own, haha.
Old 04-08-2008, 03:37 PM   #34
Forgive the crappy paint...
It's the thing I outlines in purple...
That needs to be secured to the engine block.
It's normally secured on the long bolt (and nut) that secures the starter to the engine.
That's the main engine ground.
Old 04-08-2008, 05:24 PM   #35
SO, YOU ESTABLISHED THAT HTE ALTERNATOR IS FINE AND CHARGING THE NEW BATTERY, RIGHT? Sorry, caps lock.
You said the battery terminals are fine but try using dielectric grease too. Make sure you're not losing power via a stray wire and I'm with 85rx-7-gsl-se. Make sure your power wires to the starter are not loose.
Old 04-08-2008, 05:35 PM   #36
My5ABaby
My5ABaby's Avatar
Hmm, I could swear mine was bolted to my fender or something... Oh well, I'll defer to you on this.
Old 04-08-2008, 05:49 PM   #37
$100T2
Big Daddy
$100T2's Avatar
Yes, the alternator charges the battery... As soon as the car starts running, the voltage goes right up to 14.5-15.
Here's tonight's pics of loose wires and assorted shit.
Old 04-08-2008, 05:50 PM   #38
$100T2
Big Daddy
$100T2's Avatar
Moar.
Old 04-08-2008, 05:51 PM   #39
$100T2
Big Daddy
$100T2's Avatar
Still moar.
Old 04-08-2008, 05:52 PM   #40
$100T2
Big Daddy
$100T2's Avatar
That red then blue wire, I yanked out from underneath the car. I don't know what it goes to.
Old 04-08-2008, 06:09 PM   #41
My5ABaby
My5ABaby's Avatar
Kinda random, but where does the red power cable that's coming off the battery go to? I don't think it's related, just curious.
Old 04-08-2008, 06:21 PM   #42
$100T2
Big Daddy
$100T2's Avatar
Amplified tube in the trunk.
Old 04-08-2008, 06:25 PM   #43
My5ABaby
My5ABaby's Avatar
Oh, and get a fan shroud.
Old 04-08-2008, 06:27 PM   #44
This has to be the largest tech thread to solve the simplest of problems.
Not hating, but come on, replace the damn starter already.
And connect that GROUND CABLE!!!!
Old 04-08-2008, 06:27 PM   #45
$100T2
Big Daddy
$100T2's Avatar
Why? It never goes over 1/3 on the temp gauge. Runs fantastic when it starts. I just need the RB pre-silencer and a new starter.
