| Introduce yourself!! Tell me something about you and your history with rotary.. |
240sx guru
Hey!
Whats up, my names Jared and I have a 1984 Mazda Rx-7 Gs 5-Speed. This is the first rotary car i have ever owned. I was invited to this site by Dzire, AKA Hobbie. My car is currently at his house now. I'm having some idleing issues with the 7. I dont have much vacuum pressure and because of that, my throttle opener dont work. every time i want to go some where, i have to mix gas and oil in a 20oz bottle and pour it in the carb. it will smoke like a tar kettle for a little bit but it will eventually clear up. after that, the car runs and drives, its just hard to keep it running. any one got any ideas? any info helps and is greatly appreciated.
Get off my lawn!!!
Rep Power: 15 ![]() |
Welcome to RCC man!
I wish I could help you on your issue, infortunately I have ZERO experience with carb'd vehicles though
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
Welcome.
welcome to RCC good to see you here
did a compression check on it last night and it was bad 25 psi on the front rotor and 65 psi on the rear rotor
![]() RX8 2004 GT RX7 1988 TII |
240sx guru
thanks everyone. so Hobbie, i found another 13b. but i still want that second gen you have. im still researching on the 12a to 13b swap. the lik you sent me helped alot.
Will the 13b flywheel work with the 12a transmission?
from everything that I have read it will work
by the way any engine you buy make sure you compression tested
240sx guru
i was planning on it lol, i aint making the same mistake again.
