Mazda Lover
Neutral Switch MTX
How important its it? Mine just broke all the wires off of it reinstalling it, do i need to worry about it, or should i try to repair it?
![]() 2004 Mazda6 V6 5-spd - still waiting on money for a motor 1991 Mazda RX7 NA 5-spd - my new DD with 145,000 miles |
Rotary & Boost Addict
Where the hell is the facepalm smiley? Damn Tom......lol
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs |
Rep Power: 10 ![]() |
Stock ECU reads it.
OD switch is also read by the stocker ECU.... Stock ECU's suck I use mine for start in gear protection and for my remote start
#4 | ||
Half bubble off plumb
I can't remember if FD's have this as well, if so that would work great with a remote start, yes I do realize this is the 2nd gen section...
J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
Mazda Lover
I guess I will try to repair it then
last one I bought was like $30..... just saying, some things ain't worth the aggrevation
#7 | |
I used it as the gnd for a relay that allows power to pass through it for ththe remote start
Mazda Lover
30 bucks aint bad, hopefully the local dealer has one in stock
#9 |
![]() Does Ray manage your dealers parts dept?
#10 | |||
Thats exactly what I would want it for... I want that new alarm the 'drone' I think it's called.... Everything is done via internet/SMS and you can track your cars local by GPS too.... But I did not want to put in one if I could not use a neutral safety switch easily.... Thank Goodness Mazda has a habit of over engineering some things :P J.
#11 |
Mazda Lover
alright, what the fuck does the ecu read it for? I think im going to try to "repair" it tonight, and hope i can make it work. I called 3 dealers this morning and the earliest they could get it would be next week, which is too far away.
#12 |
Rep Power: 15 ![]() |
To let the ECU know that your in gear so it can anticipate the car being driven.
It's timing related and idle speed control (BAC) and deceleration control (fuel cut) related among other things. See manual. Mazda isn't special in having a neutral switch. |
#13 |
Mazda Lover
So, the switch is open when its in gear, and closed when it is in neutral? so in leaving the switch alone not plugged in, it always thinks its in gear, right, so there really shouldn't be any harm in just leaving it?
#14 |
Idle and afr's might be a little wonky
As much as I don't like them.... MT might have one in stock, as much as I LIKE him, Ray should have one in stock as well
#15 |
Mazda Lover
MT?
