Old 04-23-2011, 09:43 PM   #31
lh6601
Down with OPP
lh6601 is on a distinguished road
You sir are a bad ass. Amazing car.
86 base, TII swapped, Rtek 2.1, some other things. Daily driven.
lh6601 is offline   Reply With Quote
Old 04-25-2011, 11:06 AM   #32
hIGGI
hIGGI is on a distinguished road
Thanks guys!
There is still a lot things to fix and work on, but its driveable and it could be taken to the track for competition, which is important for me.
Here is short vid from testing session :
http://vimeo.com/22772185
hIGGI is offline   Reply With Quote
Old 05-01-2011, 05:56 PM   #33
Kim
OBEY YOUR MAZDA
Kim's Avatar
Kim is on a distinguished road
Sweet Higgs.
I really should have a vacation and come visit one day.
Kim is offline   Reply With Quote
Old 05-16-2011, 04:33 PM   #34
hIGGI
Small update :
Still dealing with ECU injector driver overheating, but in meantime managed to win round 2 of Czech Drift Series (Street class, no rollcage).
Here is small vid :
http://www.youtube.com/watch?v=NeXs_tqqIa4
Old 05-16-2011, 10:43 PM   #35
Good job!
Seen the pics of the podium, but my Czech is still kinda lacking...
Dobrư!
Old 05-17-2011, 12:26 AM   #36
hIGGI
Thanks!
Old 05-20-2011, 12:56 AM   #37
hIGGI
loving this pic
Old 07-26-2011, 04:45 PM   #38
hIGGI
Ok, more updates
Switched to Common mode, moved staging point lower, re-tuned fuel map but problem still persist.
Injector duty cycles are hitting only 70% in peak now(both primary/secondary), but ECU is still hot and after one hour of beating it, it starts shutting down injector driver.
Turning key on/off (reseting ECU) gets it back running immediately, but once higher rpm's/boost is applied, it overloads and shuts again.
Now, new idea to deal with problem :
If my problem is really caused by shutting down injector driver, i could run secondaries on external injector driver (taking the heat out of Haltech)
http://www.fjoracing.com/products/injdrvr/
I just need it here tomorrow, to try it out.
Old 08-25-2011, 07:25 PM   #39
JACK HARPER
JACK HARPER is on a distinguished road
Awesome!!!
JACK HARPER is offline   Reply With Quote
Old 10-17-2011, 03:28 PM   #40
hIGGI
Short update now, more little bit later....
Season is over (last race was this weekend at GP track in Brno, finished 1st in street class, 2nd place overall.
Technically : ECU problems solved by cutting 2 large holes to Haltech case and putting 2 computer fans there. Worked without any problems for last 3 races.
One month ago stock TII transmission died, i replaced it with another one and enjoyed last race. Now its time to order transmission rebuild kit and build one perfect trans + one good spare case.
Hopefully will be able to post some pics/vids.
Old 10-17-2011, 06:01 PM   #41
Ian
REIAN
Ian is on a distinguished road
Awesome to hear this higgi!
1989 Turbo II. Track Car
1988 10thAE. Garage Queen 400+rwhp
Ian is offline   Reply With Quote
Old 10-31-2011, 02:58 AM   #42
hIGGI
Ok, here is my solution which actually fixed problem.
I drilled two fairly large holes into PS2000 case and fixed 2 big computer fans on it and run car with it last 3 races. When i forgot switch fans on, ECU will shuts injector drivers occasionally....when i have switch on, it never dies.....
Old 11-01-2011, 02:54 AM   #43
hIGGI
Old 12-02-2011, 02:12 AM   #44
ta4545
ta4545 is on a distinguished road
Nice!
ta4545 is offline   Reply With Quote
Old 10-22-2012, 04:11 PM   #45
hIGGI
another season has passed, another 2nd place in championship (i keep right to skip race which i dont think is worth of going to )
some pictures/vids from last race here
http://vimeo.com/51560538
http://vimeo.com/51535169
http://www.youtube.com/watch?v=7EZ_DSKkN2M
https://picasaweb.google.com/1165043...ftSeriesFinale
